TA的每日心情 | 开心 4 小时前 |
签到天数: 3583 天 连续签到: 3 天 [LV.Master]2000FPS
楼主 |
发表于 2024-11-30 17:13:49
宝视纳Basler-blaze pylon补充软件包 1.7.1 - Linux ARM 64位 - Debian安装软件包~pylon-supplementary-package-for-blaze-1.7.1.8261b56b5_arm64.deb
pylon Supplementary Package for ToF Camera / blaze 1.7.1
2024年9月
1.7.1
Compatible with: pylon 6.2.0, 6.3.0, 7.0.0, 7.2.1, 7.3.0, 7.4.0, 7.5.0, 8.0.0
在此处下载blaze pylon补充软件包,轻松设置和配置Basler blaze 3D相机。这个软件包包含blaze Viewer,以作为配置和可视化工具。
安装要求
blaze pylon补充软件包需要安装pylon相机软件套装6.2.0或更高版本。
文件名: pylon-supplementary-package-for-blaze-1.7.1.8261b56b5_arm64.deb
文件大小: 83125588 字节 (79.27 MB)
修改日期: 2024-10-24 18:28
MD5: 626924e2094cfc75ccef50dbc1881a09
SHA1: af482962756b71e642e30371cef0d5d4cc0aae2b
SHA256: c61ce005fd9fe022564bdd219453ff8ddadc2fce5984716faf4677423e0bdae6
CRC32: 152ca5d5
Basler官方下载:
链接:https://pan.baidu.com/s/1PkFhpzFXA3PV9D2rQpLM9Q
RELEASE NOTES
pylon Supplementary Package for blaze
Version: 1.7.1
Release date: 2024-09-27
Preceding release: 1.7.0
Products affected: blaze-101 (order number 107796), revisions 03 or above
blaze-102 (order number 108711)
blaze-112 (order number 109245)
CHANGES
* Added support for the Basler pylon Camera Software Suite version 8.0.
KNOWN LIMITATIONS
Windows, pylon versions below pylon 7.2.1:
- Basler generally recommends using pylon 7.3 or above with blaze cameras.
Linux:
- Programming samples using the Point Cloud Library (PCL) may crash depending
on the versions of the PCL and VTK libraries installed on your system. The
crash is due to a bug in the VTK libraries that are used by PCL for 3D
visualization.
Source: https://github.com/PointCloudLibrary/pcl/issues/5237
For example, Ubuntu 22.04 ships versions of the libraries showing the problem.
Solution: PCL 1.13.1 and above contain fixes to work around the VTK bug.
Uninstall the PCL libraries provided by your Linux distribution and build PCL
version 1.13.1 or above from sources (these are available on
https://github.com/PointCloudLibrary/pcl).
