查看: 413|回复: 0
[驱动] 宝视纳Basler-blaze pylon补充软件包 1.5.0 - Linux ARM 64位 - Debian安装软件包~FirstSpirit_pylon-supplementary-package-for-blaze-1.5.0.def07388_arm64.deb
    4 小时前
  • 签到天数: 3562 天
    连续签到: 7 天
     楼主| 发表于 2024-11-30 16:40:07 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    pylon Supplementary Package for ToF Camera / blaze 1.5.0
    2023年9月
    1.5.0
    Compatible with: pylon 6.2.0, 6.3.0, 7.0.0, 7.2.1, 7.3.0, 7.4.0
    在此处下载blaze pylon补充软件包,轻松设置和配置Basler blaze 3D相机。这个软件包包含blaze Viewer,以作为配置和可视化工具。
    安装要求
    blaze pylon补充软件包需要安装pylon相机软件套装6.2.0或更高版本。
    文件名: FirstSpirit_1697189443895pylon-supplementary-package-for-blaze-1.5.0.def07388_arm64.deb
    文件大小: 82287452 字节 (78.48 MB)
    修改日期: 2024-03-12 22:15
    MD5: ece2a7756492d73ac6ea768fca42574b
    SHA1: bbcec7438ff1da25c1aece66e0957c707c3a3334
    SHA256: fb9b5a41a1341b5b69656a8d1f98985f36e5f9017b13ff39b6bc8470f0db0e1f
    CRC32: 4c849713
    Basler官方下载:
    链接:https://pan.baidu.com/s/1NLaf8wPGRr-8WruGnwoCGw
    RELEASE NOTES
    pylon Supplementary Package for blaze
    Version:           1.5.0
    Release date:      2023-09-30
    Preceding release: 1.3.1
    Products affected: blaze-101 (order number 107796), revisions 03 or above
                       blaze-102 (order number 108711)
    NEW FEATURES
    * Added support for new camera features introduced by blaze firmware version
      5.0.0.
    * The GenTL producer for blaze cameras is compliant with the GenTL standard
      version 1.6.
    * Added the MultiCam/DepthFusion C++ programming sample illustrating how to
      calibrate a system consisting of multiple Basler blaze cameras.
    * Added the ColorAndDepth_SynchronousFreeRun Python programming sample
      illustrating how the PTP and the Synchronous Free Run features help you to
      capture data from a 2D and a blaze camera.
    * The installation packages for Linux ARM include Python samples as
      the Harvester's Python module, which is used for accessing blaze cameras,
      recently became available for Linux ARM.
    * Added C++ programming samples illustrating how to use the Aravis open source
      library for accessing blaze cameras.
    * The GenTL producer for blaze cameras provides the additional 'newestOnly'
      and 'oldestFirstOverwrite' buffer handling modes.
    CHANGES
    * Increased performance of the ShowPointCloud Python programming sample.
    * Fixed bugs and increased performance of the ColorAndDepthFusion Python
      programming sample.
    * Fixed an issue causing the ROS node for blaze cameras to crash when receiving
      a kill signal.
    * Fixed an issue preventing the blaze Viewer to run on CPUs without AVX support,
      like some Intel Celeron CPUs.
    * Fixed an issue causing the blaze Viewer's File Save dialog to crash on some
      Ubuntu setups.
    * Fixed an issue causing a connection loss when issuing a PtpDataSetLatch
      command.
    * Fixed font size-related issues of the blaze Viewer on systems with high
      resolution displays.
    * Fixed an issue causing the blaze Viewer to save corrupted 16-bit .tiff images.
    * Fixed an issue preventing web browsers installed as snap packages from opening
      the blaze Programmer's Guide. This was the case for Mozilla Firefox on Ubuntu
      22.04, for example.
    KNOWN LIMITATIONS
    Windows, pylon versions below pylon 7.2.1:
    - If the Extended IDs feature is enabled, acquiring images is not possible.
      Either disable extended IDs or select the socket driver as stream grabber
      type. How to configure the stream grabber type:
      blaze Viewer: Data Stream -> Extended Stream Control -> Type of Stream Grabber
      C++: camera.GetStreamGrabberParams().Type.SetValue(Type_SocketDriver);
      C#:  camera.Parameters[PLStream.Type].SetValue(PLStream.Type.SocketDriver);
    - Basler generally recommends using pylon 7.3 or above with blaze cameras.
    Linux
    - Programming samples using the Point Cloud Library (PCL) may crash depending
      on the versions of the PCL and VTK libraries installed on your system. The
      crash is due to a bug in the VTK libraries that are used by PCL for 3D
      visualization.
      Source: https://github.com/PointCloudLibrary/pcl/issues/5237
      For example, Ubuntu 22.04 ships versions of the libraries showing the problem.
      Solution: PCL 1.13.1 contains fixes to work around the VTK bug. Uninstall the
      PCL libraries provided by your Linux distribution and build PCL version 1.13.1
      or newer from sources (these are available on
      https://github.com/PointCloudLibrary/pcl).
    GMT+8, 2025-6-9 12:03
