查看: 830|回复: 0
[驱动] 宝视纳Basler-Basler blaze固件6.0.0~blaze-firmware-6.0.0.zip
  • 签到天数: 3781 天
     楼主| 发表于 2024-11-30 16:28:36 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    Basler blaze Firmware 6.0.0
    2024年1月
    6.0.0
    Basler blaze ToF相机的固件版本中包括blaze固件更新包、固件更新工具指南以及安装说明。
    此固件版本支持HDR功能。
    在更新固件时,Basler建议也同时更新主机软件。如需详细了解固件和主机软件之间的依赖性关系,请参阅固件版本说明。
    Basler blaze固件6.0.0
    文件名: blaze-firmware-6.0.0.zip
    文件大小: 131253809 字节 (125.17 MB)
    修改日期: 2024-10-24 18:29
    MD5: 138fc21dac092c61f9159eff2d656b06
    SHA1: 9659d20f87e99b84cbfae4203ba6275289408089
    SHA256: 732c46fb7e2515661f6a0b2cdc7e944e8be5324887cac728d64dedf6d6f1dca7
    CRC32: 101f9821
    Basler官方下载:
    链接:https://pan.baidu.com/s/1lDa5FW3-kBAazP_eTQWN5g
    RELEASE NOTES
    Note: Firmware versions not listed in this document are not released publicly.
          They are created for internal purposes only and don’t contain any changes
          that would affect the behavior of the camera. On occasion, cameras with
          such a firmware version may be shipped to customers. Updating cameras to a
          higher version than the latest publicly available firmware is not required
          since such an update would not change camera functionality or add new
          features.
    Version:           6.0.0
    Release date:      2024-09-10
    Preceding release: 5.1.0
    Products affected: blaze-101 (order number 107796), hardware revisions 09 to 20
                       blaze-102 (order number 108711), hardware revisions 01 to 07
                       blaze-112 (order number 109245), hardware revisions 01 to 03
    NEW FEATURES
    * Added the ComponentIDValue parameter. This is a unique identifier that
      indicates the type of the component selected by the ComponentSelector
      parameter.
    * Added the Scan3dProjectionModel parameter that describes the mapping
      function used for distortion correction.
    * Added the Trigger Thermal Drift Stabilization feature. If the trigger mode with
      thermal drift stabilization is enabled, the camera continuously acquires
      images in the background at a constant frame rate (fps) and sends the next
      available image when triggered. This reduces the thermal offset error and
      improves the absolute accuracy.
    CHANGES
    * Fixed the ZOffsetOriginToCameraFront parameter. It now describes the distance
      between the front of the housing and the optical center of the camera.
    * Fixed a bug that sometimes caused FrameTriggerWait not to be set to true
      when executing AcquisitionStart.
    * Fixed a bug that caused the upper limit to be adjusted incorrectly when
      using the shiftable working range and the entire measuring range couldn't
      be used.
    COMPATIBILITY INFORMATION
    *WARNING:* Because of bugs in pylon 7.1 and pylon 7.2, avoid using the blaze
      camera with pylon 7.1. or pylon 7.2. Using the latest pylon version or using
      pylon 7.0 or below is recommended.
      When using pylon 7.1, image acquisition may stop unexpectedly. When using
      pylon 7.2, image acquisition may be unstable.
    *WARNING:* Once updated, the firmware can't be downgraded to a firmware
      version below 4.2.
    *WARNING:* To update the camera's firmware to firmware version 4.0 or above,
      the camera's current firmware version has to be at least 2.3.0.
      If the current firmware version is below 2.3.0, you first have to update
      the camera to firmware version 3.0.1. Afterwards, you can perform an update
      with the latest camera firmware version. Contact Basler support to get an
      update package for firmware version 3.0.1.
    The latest Basler software for blaze cameras can be downloaded here:
    http://www.baslerweb.com/blaze-software
    GMT+8, 2026-1-23 22:20
