查看: 697|回复: 0
[驱动] 宝视纳Basler-Basler blaze固件5.1.0~blaze-firmware-5.1.0.zip
    4 小时前
  • 签到天数: 3562 天
    连续签到: 7 天
     楼主| 发表于 2024-11-30 16:26:10 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    Basler blaze Firmware 5.1.0
    2024年1月
    5.1.0
    Basler blaze ToF相机的固件版本中包括blaze固件更新包、固件更新工具指南以及安装说明。
    此固件版本支持HDR功能。
    在更新固件时,Basler建议也同时更新主机软件。如需详细了解固件和主机软件之间的依赖性关系,请参阅固件版本说明。
    Basler blaze固件5.1.0
    文件名: blaze-firmware-5.1.0.zip
    文件大小: 130633647 字节 (124.58 MB)
    修改日期: 2024-10-24 17:51
    MD5: a1b11a14f493c948e23ba0b246afae02
    SHA1: 392e9ce0a6a92f4f952ae37686bc3b1d917d37b9
    SHA256: ebfb2997d418ca51953527941a6fa86ac9d44800fb255cd35ed98bf91b9c8dee
    CRC32: 27e0f5e8
    Basler官方下载:
    链接:https://pan.baidu.com/s/1NrTbCgLTXwutshSilT45JA
    RELEASE NOTES
    Note: Firmware versions not listed in this document are not released publicly.
          They are created for internal purposes only and don’t contain any changes
          that would affect the behavior of the camera. On occasion, cameras with
          such a firmware version may be shipped to customers. Updating cameras to a
          higher version than the latest publicly available firmware is not required
          since such an update would not change camera functionality or add new
          features.
    Version:           5.1.0
    Release date:      2024-04-25
    Preceding release: 5.0.0
    Products affected: blaze-101 (order number 107796), hardware revisions 09 to 20
                       blaze-102 (order number 108711), hardware revisions 01 to 07
    CHANGES
    * Redcued trigger jitter to prevent incorrect measurements in multi-camera setups.
    * Reduced the execution time of the AcquistionStart command.
    * The AcquisitionFrameRate and BslResultingAcquisitionFrameRate parameters now display
      decimal places to represent the exact frame rate used.
    * Increased the maximum sensor board temperature until shutdown occurs from 70 °C to 75 °C.
    * Fixed an issue causing the FrameTriggerWait parameter not being reset when the AcquisitionStop
      command was executed.
    * Fixed an issue causing the DeviceLinkThroughputLimitMode parameter not to set an inter-packet delay.
    * Fixed an issue causing random image loss at high resend rates.
    COMPATIBILITY INFORMATION
    *WARNING:* Because of bugs in pylon 7.1 and pylon 7.2, avoid using the blaze
      camera with pylon 7.1. or pylon 7.2. Using the latest pylon version or using
      pylon 7.0 or below is recommended.
      When using pylon 7.1, image acquisition may stop unexpectedly. When using
      pylon 7.2, image acquisition may be unstable.
    *WARNING:* Once updated, the firmware can't be downgraded to a firmware
      version below 4.2.
    *WARNING:* To update the camera's firmware to firmware version 4.0 or above,
      the camera's current firmware version has to be at least 2.3.0.
      If the current firmware version is below 2.3.0, you first have to update
      the camera to firmware version 3.0.1. Afterwards, you can perform an update
      with the latest camera firmware version. Contact Basler support to get an
      update package for firmware version 3.0.1.
    The latest Basler software for blaze cameras can be downloaded here:
    http://www.baslerweb.com/blaze-software
    GMT+8, 2025-6-9 12:08
