TA的每日心情 | 擦汗 4 小时前 |
签到天数: 3562 天 连续签到: 7 天 [LV.Master]2000FPS
楼主 |
发表于 2024-11-30 16:19:13
宝视纳Basler-Basler blaze固件4.6.2~blaze-firmware-4.6.2.zip
Basler blaze Firmware 4.6.2
2023年3月
4.6.2
Basler blaze ToF相机的固件版本中包括blaze固件更新包、固件更新工具指南以及安装说明。
此固件版本支持HDR功能。
在更新固件时,Basler建议也同时更新主机软件。如需详细了解固件和主机软件之间的依赖性关系,请参阅固件版本说明。
文件名: blaze-firmware-4.6.2.zip
文件大小: 129653958 字节 (123.65 MB)
修改日期: 2023-04-04 21:00
MD5: 82ce1a0538e4c4268390db845fc51444
SHA1: bda79756ef7ea50e5b9ce84565956aee2066579c
SHA256: 3aad05e60d4ed05d2e126ada47b4e3206e2374324e26aaa4f32344fdb16f5b2d
CRC32: 3e5d5bc2
链接:https://pan.baidu.com/s/1v2QA1tvQtCMoeJfZlS5kdg
RELEASE NOTES
Note: Firmware versions not listed in this document are not released publicly.
They are created for internal purposes only and don’t contain any changes
that would affect the behavior of the camera. On occasion, cameras with
such a firmware version may be shipped to customers. Updating cameras to a
higher version than the latest publicly available firmware is not required
since such an update would not change camera functionality or add new
features.
Version: 4.6.2
Release date: 2022-10-24
Preceding release: 4.3.1
Products affected: blaze-101 (order number 107796), hardware revisions 09..16
blaze-102 (order number 108711), hardware revisions 01..03
NEW FEATURES
* Added the Extrinsic Transformation feature that allows you to transform the
position and orientation of the camera coordinate system.
See https://docs.baslerweb.com/extrinsic-transformation for more details.
* Improved the Outlier Removal feature by adding the OutlierRemovalTolerance
parameter.
See https://docs.baslerweb.com/outlier-removal for more details.
* Added support for Basler pylon's firewall traversal functionality.
* Provided more options for controlling the device network bandwidth
consumption. The following camera parameters have been added:
- DeviceLinkThroughputLimitMode
- BslResultingAcquisitionFrameRate
- BslDeviceLinkCurrentThroughput
- GevSCBWR (Bandwidth Reserve)
- GevSCBWRA (Bandwidth Reserve Accumulation)
* Added support for Extended IDs as defined by the GigE Vision Streaming
Protocol. Requires pylon 7.2 or above. If Extended IDs are enabled, the
frame counter reported by pylon's grab result objects doesn't wrap around
from 65535 to 1 anymore. Packet resend error handling is more efficient when
Extended IDs are enabled.
To enable Extended IDs, set the GevGVSPExtendedIDMode parameter to "On".
CHANGES
* Optimized depth calculation leads to reduced latency (timespan from trigger
to data received by host). The typical latency is less than 85 ms. This can be
reduced further by enabling the Fast Mode feature and/or disabling time-hungry
camera features like the temporal filter.
* Improved GigE Vision standard compatibility. The latest GigE Vision standard
version 2.2 is supported.
* Improved error handling when invalid camera parameters are set.
* 100 MBit connections are detected, and the frame rate is automatically
limited when a 100 MBit link instead of a 1 GBit connection is established.
* Reduced number and length of streaming data network packet bursts to
decrease the likelihood of network packets getting dropped by the receiving
host.
* Reduced bandwidth consumption when intensity images and confidence
images are disabled.
* Fixed bug: When the network connection was lost, camera settings were
reset.
* Fixed bug: Toggling the PtpEnable parameter caused grab failures.
* Fixed bug: Fast toggling of the HDRMode parameter could cause the firmware to
restart.
* Fixed bug: Cancelling image acquisition in synchronous free run was not possible
if the synchronous free run start time was set to a time in the future.
* Improved third-party software support.
* Further bug fixes and stability improvements.
COMPATIBILITY INFORMATION
*WARNING:* Because of bugs in pylon 7.1 and pylon 7.2, avoid using the blaze
camera with pylon 7.1. or pylon 7.2. Using pylon 7.0 or below is recommended.
When using pylon 7.1, image acquisition may stop unexpectedly. When using
pylon 7.2, image acquisition may be unstable.
*WARNING:* Once updated, the firmware can't be downgraded to a firmware
version below 4.2.
*WARNING:* To update the camera's firmware to firmware version 4.0 or above,
the camera's current firmware version has to be at least 2.3.0.
If the current firmware version is below 2.3.0, you first have to update
the camera to firmware version 3.0.1. Afterwards, you can perform an update
with the latest camera firmware version. Contact Basler support to get an
update package for firmware version 3.0.1.
*Note:* To use new features introduced by this firmware version,
you have to update to pylon Supplementary Package for blaze 1.3.0
or above or to Basler blaze SDK 4.3 or above.
The latest Basler software for blaze cameras can be downloaded here:
http://www.baslerweb.com/blaze-software
*Note:* Applications built using the Basler blaze SDK 3.0.0 or above or the
pylon Supplementary Package for blaze 1.0.0 or above can't access cameras with
firmware versions below 3.0.0. These cameras have to be updated to firmware
3.0.0 or above when you migrate to the pylon Supplementary Package for blaze
1.0.0 or above or to Basler blaze SDK 3.0.0 or above.
Mixing 2.x cameras with 3.x cameras in the same application is not possible.
Firmware update packages and update instructions can be downloaded here:
http://www.baslerweb.com/blaze-software |
