查看: 1153|回复: 0
[驱动] 瑷荔德Allied Vision Tech(AVT) 工业相机驱动和二次开发包Vimba_v5.1_ARM64 The SDK for AVT cameras
  • 签到天数: 3804 天
     楼主| 发表于 2024-11-28 11:23:04 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    文件名: Vimba_v5.1_ARM64.tgz
    文件大小: 53021211 字节 (50.56 MB)
    修改日期: 2024-10-25 10:51
    MD5: 4c148caf57ee43a9c9a41d531ab78fe7
    SHA1: 20f5931e226d25d0ede406081441e5ef70f61018
    SHA256: 6905dc6e178acabc1a4e854fbc6437c8c27a40be2a4364ff47958fc40a7da6f2
    CRC32: 64213b14
    AVT官方下载:
    链接:https://pan.baidu.com/s/1j_THrla2h557TAdPSw9JSw
    Changes in Vimba 5.1.0:
    VimbaC
      - New feature: Support for Alloc And Announce frame allocation mode
      - Feature endianess related fixes (corresponding to GigE TL)
    VimbaCPP
      - New feature: Supports Alloc And Announce frame allocation mode
    VimbaNET
      - New target framework version: .NET 4.7.2
    VimbaPython
    Vimba Viewer
      - Supports Alloc And Announce frame allocation mode
      - Chinese localization
      - Supports changes of GigE TL and VimbaC
      - Fixed: IP labels not updated after changing the IP via GevCameraForceAddressSend
      - Fixed: Auto ROI tab always resets ROI at startup
    Firmware Updater
      - Supports Git hash representation
    Firmware Updater Console
    GigETL
      - Changed behaviour of endianess handling (values must match host endianness in little-endian),
        for better compatibility with third-party software.
        Affected features that now have a changed byte order:
          - Config Mode
          - IP-related features including MulticastIPAddress
          - Action Commands
      - New feature DeviceUpdateTimeout (only applicable if GigE discovery is switched to Broadcast)
      - New GVSPMaxLookBack default value (0 instead of 1) for improved packet resend handling
      - Fixed: High memory usage during performance bottleneck (Nonpaged pool growing with multiple GigE cameras)
      - Fixed: Action commands caused an error message in the console log
      - Fixed: Multicast IP address range, better compatibility with third-party software
    GigE Filter Driver
      - Reduced memory allocations
      - Hidden statistics
    USB TL
    -  Fixed: Reset cameras streaming state when opened (Endpoint Halt)
    -  Updated 3rd-party libraries
    GMT+8, 2026-2-20 14:14
