TA的每日心情 | 开心 13 小时前 |
签到天数: 3583 天 连续签到: 3 天 [LV.Master]2000FPS
楼主 |
发表于 2024-11-26 18:09:36
康耐视Cognex 3D VISION SYSTEMS COGNEX IN-SIGHT 3D-L4000 1.3.2
Summary of improvements:
Added GetScanTime function/getter to know the required time to acquire a Point Cloud. This
function/getter returns true values for real acquisitions, in the case of working with filmstrips,
this getter returns zero.
Adding the option to force the Z axis on some of the 3D Fixture tools.
Now, 3D fixture tools (excluding Patmax3D) come with a checkbox that enables users
to activate or deactivate the positive Z-axis, leading to an overall improved user
experience. This addition simplifies the process of converting a 3D fixture to a 2D
one.
Solved timing issue on WriteData function when working with append mode. Previously, this
issue was causing disruptions in the order of saved data.
Solved the issue with Point Cloud generation potentially freezing the device when in Online
mode.
Solved the issue with jobs that have object referenced disabled cells being unable to load,
and the application freezing when trying to display the cell content.
Solved the issue with the TCP communication after using WriteDevice buffer.
Solved the issue of the device becoming unresponsive after:
Multiple triggers were sent.
Receiving TCP packets.
OPC UA server disconnection.
文件类型: .exe
文件大小: 590.4MB
版本: 1.3.2
发布日期: 2023/8/11
文件名: Cognex In-Sight 3D-L4000 1.3.2 Setup.exe
文件大小: 619063696 字节 (590.39 MB)
修改日期: 2023-08-11 19:12
版本: 1.3.2.4711
MD5: 8373d29375a6dcc5a51d265f8185115d
SHA1: 764e59cff231a77d494511019f96b9b1c4a86ad6
SHA256: a6790056f322399e11e4e77cc8f61144a6f6a453c84bb55c7395b325fe50b8fa
CRC32: c75625b2
康耐视官方下载:
通过百度网盘分享的文件:Cognex In-Sight 3D-L4000 1.3.2 Setu...
链接:https://pan.baidu.com/s/1FsCNr3OvTGG617OTxcPGjA
--来自百度网盘超级会员V7的分享 |
