查看: 483|回复: 0
[Cognex] 康耐视Cognex IN-SIGHT EXPLORER 5.7.1
    2 小时前
  • 签到天数: 3586 天
    连续签到: 6 天
     楼主| 发表于 2024-11-22 16:28:34 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    In-Sight 5.7.1 fixes a number of critical bugs from 5.7. Below are some key items. Please refer to the release notes for a full list of bug fixes and enhancements:
    When In-Sight Explorer is installed to a PC that is not connected to a network and an Offline Programming Key has been entered in the Options dialog, the emulator can now be connected to. For In-Sight Explorer 5.7.0, if all Ethernet network cards were disabled on the PC or if a wireless adapter was enabled but not connected to a network, the emulator could not be connected to.
    When the In-Sight 9912 vision system is connected to the CIO-MICRO I/O module, line 12 (Pass/Fail LED) and line 13 (Error LED) are now properly displayed and configurable from the Discrete I/O Settings dialog in the Spreadsheet view and from the Discrete Inputs/Outputs application step in the EasyBuilder view. Previously, these lines were not displayed and could not be configured.
    When using the WriteImageFTP function (Input/Output > Network) in the Spreadsheet view or exporting images via FTP (Communications > FTP) in the EasyBuilder view, the resolution of the exported image is now correct (Full, Quarter or Half). Previously, the resolution of the exported image did not match the setting specified within In-Sight Explorer.
    Enhancement to highlight:
    In-Sight 2000 now supports Job Server for all In-Sight 2000 models.  Previously, this was only supported on In-Sight Vision Systems.
    文件类型: .exe
    文件大小: 838.6MB
    版本: 5.7.1
    发布日期: 2019/1/10
    文件名: Cognex In-Sight Software 5.7.1.exe
    文件大小: 879296352 字节 (838.56 MB)
    修改日期: 2022-07-26 16:49
    版本: 5.7.1.1958
    MD5: 1a9870ac2107fed5af3a7c8282f64987
    SHA1: 14bc42e512c7586793b7e0aec637c1f65420b289
    SHA256: 6788b6d41a2c69626da6b0ffca315f949a656dd80da7a213dd902962f43a2568
    CRC32: 6bf4620f
    康耐视官方下载:
    通过百度网盘分享的文件:Cognex In-Sight Software 5.7.1.exe
    链接:https://pan.baidu.com/s/1PVwMrt9Uuii4uUL07jXofg
    --来自百度网盘超级会员V7的分享
    GMT+8, 2025-7-6 13:03
