TA的每日心情 | 慵懒 昨天 08:11 |
楼主 |
发表于 2024-11-22 15:28:22
康耐视Cognex IN-SIGHT EXPLORER 5.6.1
In-Sight Explorer 5.6.1 supports the new In-Sight 9902L – 2K Line Scan. Available late September. In addition, 4 critical bugs have been fixed:
If you configure the Sensor Filmstrip Queue Size to save the maximum number of images to the vision system, place the vision system Online and select an image in the filmstrip queue, the spreadsheet cell content remains intact. Previously, the contents of the spreadsheet cells might have been erased.
When an In-Sight 2000 series color vision sensor is connected to a Web HMI and it acquires images as fast as possible, the vision sensor trigger rate is no longer affected. Previously, the trigger rate could drop significantly.
For In-Sight 2000 series vision sensors with the HMI Server enabled, stability issues no longer occur when the sensor is connected to the Web HMI through a high-traffic network. Previously, the vision sensor could become unresponsive and disconnect from the network, requiring a power cycle
When you configure a Serial Text, Serial Native, TCP/IP or UDP device in the Communication application step on an In-Sight 2000 series vision sensor, the FormatString dialog box displays the Output String correctly. Previously, the FormatString dialog box displayed #ERR.
文件类型: .exe
文件大小: 747.7MB
版本: 5.6.1
发布日期: 2018/8/27
文件名: Cognex In-Sight Software 5.6.1.exe
文件大小: 784048288 字节 (747.73 MB)
修改日期: 2021-02-14 23:39
版本: 5.6.1.361
MD5: cf2c2d0eb7ed6eb50e7fd95778d49e97
SHA1: 55a82ba98408b49c9a902b6b11ce10008c153c49
SHA256: 3a64bda7d8af482bb13e27516a1203a87218586cab84c4612f0dcba0019d078c
CRC32: 33e81eac
康耐视官方下载:
通过百度网盘分享的文件:Cognex In-Sight Software 5.6.1.exe
链接:https://pan.baidu.com/s/1zVwUtFy_VFXUi-cYRyQGYA
--来自百度网盘超级会员V7的分享 |
