TA的每日心情 | 奋斗 2 小时前 |
签到天数: 3535 天 连续签到: 5 天 [LV.Master]2000FPS
楼主 |
发表于 2024-11-22 14:35:32
康耐视Cognex IN-SIGHT OPC SERVER 5.4
The In-Sight OPC Server provides access to In-Sight spreadsheet cell data from OPC clients based on versions 1.0, 2.0 or 3.0 of the OPC Specification. In order for In-Sight cell data to be visible to OPC clients, "OPC tags" are inserted into spreadsheet cells that contain data on an In-Sight vision system. Once a tag has been applied to a cell, the In-Sight OPC Server is then configured to publish the tag and its associated value so that OPC clients can access it.
You must be logged on as a user with full administrative privileges in order to install the In-Sight OPC Server and you must disable User Account Control (UAC) before installing the In-Sight OPC Server. For instructions on how to disable UAC, do the following:
Windows 7/Windows Sever 2008 R2
1. Click Start > Help and Support.
2. In the search box, type: Turn off UAC
3. Press ENTER.
4. View the first search result topic entitled "Turn User Account Control on or off".
Windows 10
You must disable UAC from Registry Editor by manually changing the value.
Note: Disabling UAC from the Control Panel (User Accounts) will not allow you to install the In-Sight OPC Server
on Windows 10.
1. Press the Windows key + R on your keyboard. The Run dialog opens.
2. Type regedit and click OK. Registry Editor opens.
3. Select HKEY_LOCAL_MACHINE > SOFTWARE > Microsoft > Windows > Current Version > Policies >
System.
4. Right-click on EnableLUA, and select Modify. The Edit DWORD Value dialog opens.
5. Change the Value data to 0.
6. Click OK to close the dialog.
7. Restart your PC. Now you can install the In-Sight OPC Server.
After installation, you may re-enable UAC; however, in order to uninstall the In-Sight OPC Server you will need to disable it temporarily again
文件类型: .exe
文件大小: 32.0MB
版本: 5.4
发布日期: 2017/3/20
文件名: Cognex In-Sight OPC Server 5.4.0.exe
文件大小: 33534008 字节 (31.98 MB)
修改日期: 2021-02-14 23:05
版本: 5.4.368.0
MD5: 7db2e44ff3538b43ed16457dcd72ccb5
SHA1: d1974080c413e3a30bfdd1c7acfe5a05b21a85ed
SHA256: 635275ab71db219f8d01f23b39fd4648b508bb49ee896e44fe94f5e26c08cf40
CRC32: dd5c70e9
康耐视官方下载:
通过百度网盘分享的文件:Cognex In-Sight OPC Server 5.4.0.exe
链接:https://pan.baidu.com/s/1CJDOxZMMo5n2B_Lovo-IKg
--来自百度网盘超级会员V7的分享 |
