TA的每日心情 | 奋斗 1 小时前 |
签到天数: 3535 天 连续签到: 5 天 [LV.Master]2000FPS
楼主 |
发表于 2024-11-22 14:28:48
康耐视Cognex IN-SIGHT 5.3 PR1 SOFTWARE PATCH
In-Sight 5.3.0 PR1 is a firmware-only release for In-Sight 5705C vision systems running firmware version 5.3.0.
This release includes a fix for White Balance functionality, to properly remove color casts in the acquired image by calculating the image's red, green and blue (RGB) values and correcting them according to color tables stored in the In-Sight job.
To install the firmware to the vision system:
Extract the contents of the In-Sight Explorer 5.3 PR1 Patch Installer.zip file to your PC.
Run Update.exe. This will copy the patched 5705C firmware to your PC (C:\ProgramData\Cognex\Firmware\In-Sight\5.3.0\is5700.upd).
Launch In-Sight Explorer and navigate to System menu > Update Firmware.
Find the 5705C vision system(s) in the list and verify that the “New Version” column displays “5.03.00 PR1 (171)”.
Upgrade the 5705C vision system(s) normally.
White Balance can be applied by executing the WhiteBalance spreadsheet function, pressing the White Balance button in the AcquireImage property sheet or pressing the White Balance button in the EasyBuilder Setup Image application step. (CR#44005)
文件类型: .zip
文件大小: 12.0MB
版本: 5.3.0 PR1
发布日期: 2016/12/8
文件名: In-Sight Explorer 5.3 PR1 Patch Installer.zip
文件大小: 12557379 字节 (11.98 MB)
修改日期: 2021-02-14 23:25
MD5: ef77336304b49d4fd1bd240a599b5bea
SHA1: 52130c7ba53e42b5f78b7e94be85a5668c5c5b4d
SHA256: 35b752deb98ac3450bc4182f5bc7f683b6a0a49e786103221e7b522083991287
CRC32: d49042fd
康耐视官方下载:
通过百度网盘分享的文件:In-Sight Explorer 5.3 PR1 Patch Ins...
链接:https://pan.baidu.com/s/10y1ru3iP1blrBjPElF9TlQ
--来自百度网盘超级会员V7的分享 |
