TA的每日心情 | 郁闷 9 小时前 |
楼主 |
发表于 2024-11-22 14:25:47
康耐视Cognex IN-SIGHT EXPLORER 5.3
This release includes In-Sight Explorer 5.3.0 and the latest firmware for all currently shipping In-Sight vision sensors/systems:
In-Sight 2000 vision sensor models (5.3.0)
In-Sight 5705/5705C and 8000 series vision systems (5.3.0)
In-Sight Advantage Engine (5.2.2)
In-Sight Micro 1xxx, 51xx/54xx/56xx and 7000 series vision systems (4.10.3)
In-Sight 2000 Series vision sensors-only:
Adds support for the new In-Sight 2000-120C/130C color models, including an easy-to-use Color Pixel Count tool for simple presence/absence applications.
Adds numeric results output for Measurement > Distance, Angle and Diameter and
Counting > Patterns and Edges tools. (2000-130/130C models-only). Distance and Diameter measurements can be converted from pixels to real world units.
Adds support for the CIO-1400 I/O Expansion Module accessory, which increases the number of available general purpose inputs and outputs to 7 and 8, respectively, while providing convenient access to RS232 serial communications. With the additional inputs, it is not necessary to use the pulsed input method to change jobs.
Adds support for basic In-Sight Native Mode commands via Telnet and RS232, including commands to save and load job files on the sensor.
Adds support for TCP/IP and UDP protocols to the 2000-110 and 2000-120 models.
Adds option to increase the size of the image buffer, which can minimize the possibility of missed acquisition triggers in some higher speed applications.
It is now possible to connect to an IS2000 sensor with a static IP address on a different subnet.
In-Sight 5705/5705C and 8000 Series vision systems-only:
Adds support for the CIO-Micro I/O Expansion Module accessory which increases the number of available general purpose inputs and outputs to 7 and 8, respectively, while providing convenient access to RS232 serial communications.
In-Sight 2000 Series vision sensors, and In-Sight 5705/5705C and 8000 Series vision systems:
Adds Modbus TCP protocol support, making it easier to integrate In-Sight with inexpensive PLCs.
Officially supports PCs running 64-bit Windows 10.
Many other enhancements and bug fixes…
In-Sight Micro 1xxx, 51xx/54xx/56xx and 7000 series vision systems:
Adds In-Sight Explorer option to between passed and failed images on the In-Sight Explorer filmstrip.
文件类型: .exe
文件大小: 635.0MB
版本: 5.3.0
发布日期: 2016/11/1
文件名: Cognex In-Sight Software 5.3.0.exe
文件大小: 665857904 字节 (635.01 MB)
修改日期: 2021-02-14 23:17
版本: 5.3.860.0
MD5: 5addf741417deae8c485cf324602a916
SHA1: 2d6ea64cd1d2ebfd44bb16d79230d32ffc850c9c
SHA256: 705404f60b787422f07be43ba41df11062e717512bcc341dcab9bbb7918b3ccf
CRC32: d8362d7e
康耐视官方下载:
通过百度网盘分享的文件:Cognex In-Sight Software 5.3.0.exe
链接:https://pan.baidu.com/s/1AVFY94V1O0s57sIojaZ8Ag
--来自百度网盘超级会员V7的分享 |
