查看: 878|回复: 0
[Cognex] 康耐视Cognex IN-SIGHT EXPLORER WAFER ID 4.5.2 FOR 1720/1740 SERIES WAFER READERS
    3 小时前
  • 签到天数: 3586 天
    连续签到: 6 天
     楼主| 发表于 2024-11-20 11:33:17 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    In-Sight Explorer Wafer ID version 4.5.2 supports the In-Sight 1720/1740 Series wafer readers. Included in wafer ID version 4.5.2 are several enhancements for improved reading performance and easier setup and operation of both In-Sight 1720 and 1740 Series wafer readers:
    • Functional VB6.0 and .NET sample apps
    • Web Browser improvements for embedded control
    • Light power mod enhancements
    • IE 7.0 compatible Tune button
    • Compression 10 and 13 options now available for BC 412
    • Checkbox enablement of SEMI checksum
    • Functional tuning using filters
    • Time is now correct when using READ command
    • Other fixes for issues reported in wafer ID 4.5.0 and earlier versions. After installing, read the Cognex Wafer ID 4.5.2, read the Release Notes for a complete list of changes and fixes contained in this release.
    NOTE:
    • The standard In-Sight Explorer 4.5.2 Software release for general purpose In-Sight vision systems does not contain the firmware and user interface files required by 1720 Series and 1740 Series wafer readers. If you already have In-Sight Explorer 4.5.2 installed on your PC, you must also install In-Sight Explorer Wafer ID 4.5.2 in order to use 1720 Series and 1740 Series wafer readers.
    • Win10 has been used in the field successfully and should work with no or little adjustments.  Please reference the help file (Troubleshooting - Internet Explorer) if WafID application doesn't load properly in Internet Explorer.
    文件类型: exe
    文件大小: 172.5MB
    版本: 4.5.2
    发布日期: 2013/3/27
    文件名: Cognex In-Sight Wafer ID 4.5.2.exe
    文件大小: 180845184 字节 (172.47 MB)
    修改日期: 2021-02-14 23:03
    版本: 4.5.506.2
    MD5: 3bc12f6f8fb11f11e58d89b0bfcbb825
    SHA1: 8d7a4946c563693f62cea6fbea7ed85e090e242e
    SHA256: e7392d63df0217f86808f6b4aca7bed1f8abf5df0f0dd5a3b94f035b76f0530c
    CRC32: 40bb1876
    康耐视官方下载:
    通过百度网盘分享的文件:Cognex In-Sight Wafer ID 4.5.2.exe
    链接:https://pan.baidu.com/s/1LWhEt3XdpDVSKmV1jD0kcA
    --来自百度网盘超级会员V7的分享
    GMT+8, 2025-7-6 14:12
