TA的每日心情 | 奋斗 4 小时前 |
签到天数: 3535 天 连续签到: 5 天 [LV.Master]2000FPS
楼主 |
发表于 2024-11-8 09:49:12
康耐视深度学习图像处理软件Cognex VisionPro Deep Learning 3.2.1 官方Windows原版非破解版
VISIONPRO DEEP LEARNING 3.2.1
VisionPro Deep Learning 3.2.1 fixes issues found in earlier version of VisionPro Deep Learning.
Resolved Issues:
AI Labeling tool can now be used through Service-Client environment
Undo function is now available on the AI Labeling tool
Processing and Training for small size images under 64 x 64 is now available
Fixed an issue where 100(%) x 100(%) ROI value set by user was sometimes randomized in the ROI setting window
Fixed an issue where VPDL gets slow when loading the database overview when the number of Tags(class) are eight or more
Fixed an issue where resize size set manually by the user could not be imported into Parameter Search in Auto Mode
Fixed an issue on Green HDM-Quick, when user accept view on image which has marking, it didn’t change into label
Fixed an issue where HDM parameter validation Set Ratio couldn’t be changed from 20%
Fixed an issue where the score was different between training API(GUI) and runtime API
Fixed a compatibility issue between VPDL 3.2.0 and VisionPro 9.20
文件类型: .zip
文件大小: 5.4GB
版本: 3.2.1
发布日期: 2024/1/30
文件名: VPDL_INSTALL_3.2.1.29175.zip
文件大小: 5807967655 字节 (5.41 GB)
修改日期: 2024-03-13 17:58
MD5: 061c2630bbe07a87f9a8160eccb035e5
SHA1: f157247c868534283cc8d781535521dfb79feb3f
SHA256: 1db4febf5cdf896c363eb207e23d12750cf4a9221bb3229176f7418fa5910135
CRC32: 1df17796
康耐视官方下载:
通过百度网盘分享的文件:VPDL_INSTALL_3.2.1.29175.zip
链接:https://pan.baidu.com/s/1uoEhN5h0s0ZwzJ394We8Ag
--来自百度网盘超级会员V7的分享 |
