查看: 1117|回复: 0
[NI软件产品] NI TestStand 2023 Q4 Semiconductor Module 2024 Q3 Win11 64bitEng Teststand2023Q4半导体模块扩展23.1.0
    6 小时前
  • 签到天数: 3794 天
    连续签到: 45 天
     楼主| 发表于 2024-10-31 08:37:09 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    TestStand Semiconductor模块
    TestStand Semiconductor模块扩展了TestStand环境,可帮助您开发、调试、部署和维护半导体测试系统。
    TestStand Semiconductor模块通过引脚/通道匹配、分箱、分选器/探针台驱动程序、限制值导入/导出和多站点编程,扩展了TestStand环境,可帮助您开发和维护半导体系统,包括晶圆级和最终封装测试应用程序。
    发布日期:2024/8/2
    包含的版本:2024 Q3完整版,版本号23.1.0
    受支持的操作系统
    应用程序位数:64位(自TestStand 2023 Q3 Semiconductor Module 2024 Q1版本开始,仅提供64位版本,不再提供32位版本)
    文件大小: 835805184 字节 (797.09 MB)
    修改日期: 2024-10-18 16:36
    MD5: 4c530a02bfe86b030d470abb7fb0f289
    SHA1: 5d6ccf3cf0b9311bc4a32f7725c5a6bbad2f365d
    SHA256: 44d335f5d981531f74584e08de2383e3615c85bed961c20a7d327c1d89ca99f4
    CRC32: 1e7eeb9d
    TestStand2023Q4Semiconductor模块2024Q3.txt (701 Bytes, 下载次数: 0, 售价: 10 圆)
    NI TestStand 2023 Q4 Semiconductor Module 2024 Q3版本未更新自述文件,参考NI TestStand 2021 Semiconductor Module 2023 Q1:
    TestStand 2021 Semiconductor Module 2023 Q1 Readme
    February 2023
    This file contains installation instructions and compatibility information for TestStand 2021 Semiconductor Module 2023 Q1.
    • TestStand Semiconductor Module Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • TestStand Semiconductor Module Documentation: New features, behavior changes, and other documentation
    TestStand 2021 Semiconductor Module 2023 Q1 has the following requirements:
    • Pentium 4/M or equivalent (Pentium G1 or higher recommended)
    • At least 350 MB of disk space. This value is in addition to the free hard disk space TestStand requires.
    • 1 GB RAM (2 GB or more recommended)
    TestStand 2021 Semiconductor Module 2023 Q1 supports the following operating systems:
    Note  TestStand Semiconductor Module no longer supports any 32-bit Windows operating system. Refer to Unsupported Windows Operating Systems for more information about support for Microsoft Windows OSes.
    TestStand 2021 Semiconductor Module 2023 Q1 supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Requirement
    Recommended
    Minimum
    Comments
    TestStand (32- or 64-bit)
    2021
    2021
    Refer to the Recommended System Requirements section of the TestStand 2021 Release Notes for information about the recommended system requirements for TestStand.
    LabVIEW (32- or 64-bit)
    2021
    2018
    TestStand Semiconductor Module APIs are compiled for the LabVIEW 2018, 2019, 2020, and 2021 Run-Time Engines. The LabVIEW operator interface, Lot and Station Settings dialog boxes, and simulated handler are compiled for the LabVIEW 2020 Run-Time Engine.
    (Optional) NI-DAQmx 16.1.0f2 or later .NET API
    The TestStand Semiconductor Module NI-DAQmx .NET Code Module API requires the NI-DAQmx 16.1.0f2 or later .NET API.
    If you are using the TestStand Semiconductor Module .NET Class Library, .NET Framework 4.0 (minimum) is required. The TestStand 2021 Semiconductor Module 2023 Q1 .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the TestStand Semiconductor Module installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Documentation for more information about installing, removing, and upgrading NI software using Package Manager.
    If you purchased this product with an NI Software Suite or NI Product Bundle, use the installation method of the Suite or Bundle.
    The TestStand Semiconductor Module installation program installs files for TestStand and LabVIEW, including the LabVIEW 2020 Run-Time Engine.
    • TestStand 2021 Semiconductor Module 2023 Q1 installs SeqEdit.exe.config in the \Bin directory and overwrites any existing file with the same filename in that directory. If you have created a custom SeqEdit.exe.config file, complete the following steps to preserve the custom file.
      • Move the existing SeqEdit.exe.config file to a location outside the directory.
      • Install TestStand 2021 Semiconductor Module 2023 Q1.
      • Compare the SeqEdit.exe.config file TestStand 2021 Semiconductor Module 2023 Q1 installed to the custom version of the file and merge the custom changes into the file TestStand 2021 Semiconductor Module 2023 Q1 installed.
    • If you are installing more than one NI product, visit ni.com/r/tsminstall for information about installation order. If you install or update LabVIEW after you install TestStand or TestStand Semiconductor Module, close and restart TestStand or run the TestStand Version Selector to properly configure LabVIEW, TestStand, and TestStand Semiconductor Module.
    • NI recommends that you exit all programs before running the TestStand Semiconductor Module installer. Applications that run in the background, such as virus scanning utilities, might cause the installer to take longer than necessary to complete.
    • Visit ni.com/info and enter the Info Code rddrau to access the latest software drivers and updates.
    Refer to the TestStand Semiconductor Module book in the TestStand Help, accessible from the Help menu in the TestStand Sequence Editor, for information about TestStand Semiconductor Module.
    TestStand Semiconductor Module includes a variety of example programs that you can use to help you learn key concepts or to serve as a starting point for applications you create. You can open an example sequence file from the subdirectories of the \Examples\NI_SemiconductorModule directory.
    TestStand Semiconductor Module no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    GMT+8, 2026-2-5 15:56
