查看: 1094|回复: 0
[NI驱动程序] NI RF Signal Generators 2024 Q4 Patch 1 Win11 32/64bitEng NI RF信号发生器NI-RFSG24.8.1
     楼主| 发表于 2024-10-30 15:31:04 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-RFSG
    NI-RFSG 2024 Q4 Patch 1
    发布日期:2024/10/8
    包含的版本:2024 Q4Patch1完整版,版本号24.8.1
    文件大小: 5502345216 字节 (5.12 GB)
    修改日期: 2024-10-17 10:38
    MD5: ee9f1b39e83baf9c13f4d13ea1eeb433
    SHA1: ffbd68f305606335e007978a9c5400947cfaea69
    SHA256: c3891472918e75ed1aeca21012b10849f36e66628b3010de07ca3dc39835341a
    CRC32: 2b34c582
    RFSG2024Q4Patch1.txt (576 Bytes, 下载次数: 0, 售价: 10 圆)
    2024Q4Patch1版未更新自述文件,参考2023Q3版
    NI-RFSG 2023 Q3 Readme
    • Support for LabVIEW 2023 Q1
    • 4 GB RAM*
    • NI Linux® Real-Time
    Versions Supported by NI-RFSG
    LabVIEW2020 and later
    LabWindows/CVI2019 and later
    Accessing the APILabVIEW
    LabWindows/CVI
    .NET Framework
    C
    NI-RFSG SFP
    Document
    Format
    Description
    • Hardware device overviews
    Document
    Format
    Description
    GMT+8, 2026-1-13 09:37
