查看: 1153|回复: 0
[NI驱动程序] NI RF Signal Generators 2024 Q4 Win11 32/64bitEng NI RF信号发生器NI-RFSG24.8.0
     楼主| 发表于 2024-10-30 15:29:08 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-RFSG
    NI-RFSG 2024 Q4
    发布日期:2024/10/8
    包含的版本:2024 Q4完整版,版本号24.8.0
    文件大小: 5502267392 字节 (5.12 GB)
    修改日期: 2024-10-17 10:25
    MD5: 59cc6b8ee7fcab6dc0bdd972dd3bae72
    SHA1: 3f9ec08cdc35ad3dd0d01c9dfdc46f8bb8192bc2
    SHA256: 5780a14ca23e6eb6e75e590c8699b2cb6e1425373f369f72513d7b109825b6c0
    CRC32: 2a69ee90
    RFSG2024Q4.txt (568 Bytes, 下载次数: 0, 售价: 10 圆)
    2024Q4版未更新自述文件,参考2023Q3版
    NI-RFSG 2023 Q3 Readme
    • Support for LabVIEW 2023 Q1
    • 4 GB RAM*
    • NI Linux® Real-Time
    Versions Supported by NI-RFSG
    LabVIEW2020 and later
    LabWindows/CVI2019 and later
    Accessing the APILabVIEW
    LabWindows/CVI
    .NET Framework
    C
    NI-RFSG SFP
    Document
    Format
    Description
    • Hardware device overviews
    Document
    Format
    Description
    GMT+8, 2026-1-13 09:38
