查看: 485|回复: 0
[NI软件产品] NI RFmx W-CDMA/HSPA+ 2024 Q4 Win11 64bitENG RFmx W-CDMA/HSPA/HSPA+蜂窝测试24.8.0
    昨天 07:09
  • 签到天数: 3534 天
    连续签到: 4 天
     楼主| 发表于 2024-10-30 14:54:40 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx W-CDMA/HSPA+
    发布日期:2024/10/8
    包含的版本:2024 Q4完整版/运行版,版本号24.8.0
    64位完整版校验和:
    文件大小: 2079248384 字节 (1.94 GB)
    修改日期: 2024-10-17 09:13
    MD5: 6232e6943bfa758c433255dd09348fa3
    SHA1: 919783088475c79de3a73a4500e762dd54213c74
    SHA256: 5228bead498648ee7282ba8d6421feff5aaf85d80985c41b25014e9f4cf6b7c6
    CRC32: 85123e12
    请注册登录视觉论坛账号,购买附件查看下载地址
    RFmx WCDMA2024Q4Full.txt (608 Bytes, 下载次数: 0, 售价: 10 元)
    64位运行版校验和:
    文件大小: 1021845504 字节 (974.51 MB)
    修改日期: 2024-10-17 09:12
    MD5: e3ab67810438990e0a5d9dbed9aff605
    SHA1: 7db1f109aeafe4f0067a5c5844539d95eb066987
    SHA256: adde924594e6419ed60867cef9c04d9546172447790c49fbe263b6f2637e3e06
    CRC32: 66236115
    RFmx WCDMA2024Q4RTE.txt (639 Bytes, 下载次数: 0, 售价: 5 元)
    2024Q4版未更新自述文件,参考2023Q3版本。
    RFmx WCDMA 2023 Q3 Readme
    • RFmx WCDMA Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx WCDMA Manuals: New features, behavior changes, and other documentation
    Installed Software
    RFmx WCDMA 2023 Q2 includes the following new feature:
    RFmx WCDMA 2023 Q1 includes the following new feature:
    RFmx WCDMA 2022 Q4 includes the following new feature:
    • Support for PXIe-5842
    RFmx WCDMA 2023 Q3 supports the following 64-bit operating systems:
    Note    RFmx WCDMA no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx WCDMA 2023 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx WCDMA 2023 Q3 to an unsupported OS. Additionally, after installing RFmx WCDMA 2023 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx WCDMA supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx WCDMA. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx WCDMA (64-bit only)
    Required Software
    Download the RFmx WCDMA installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx WCDMA. For more information on RFmx WCDMA activation, refer to National Instruments Software Activation.
    Installed Software
    Item
    Installed Location
    Import Library files
    RFmx WCDMA palette VIs are available from the Functions » Measurement I/O » RFmx » WCDMA palette.
    Documentation for RFmx WCDMA is located at Start » National Instruments » RFmx WCDMA Documentation.
    You can access all the installed RFmx WCDMA examples at Start » National Instruments » RFmx WCDMA Examples.
    The following is the behavior change in RFmx WCDMA 2023 Q3 from RFmx WCDMA 2023 Q2
    The following is the behavior change in RFmx WCDMA 2022 Q4 from RFmx WCDMA 2022 Q3
    • RFmx WCDMA drops support for 32-bit user mode.
    The following is the behavior change in RFmx WCDMA 2022 Q3 from RFmx WCDMA 21.8.2
    The following is the behavior change in RFmx WCDMA 20.7 from RFmx WCDMA 20.6.
    GMT+8, 2025-5-10 06:34
