查看: 644|回复: 0
[NI软件产品] NI RFmx Pulse 2024 Q4 Win11 64bitENG RFmx脉冲分析仪24.8.0
    半小时前
  • 签到天数: 3599 天
    连续签到: 7 天
     楼主| 发表于 2024-10-30 14:07:01 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx Pulse
    RFmx Pulse可帮助您执行交互式和自动化脉冲分析测量。
    RFmx Pulse是一款测量专用软件,可扩展NI RF仪器的脉冲分析功能,例如PXI矢量信号分析仪和PXI矢量信号收发器。借助RFmx Pulse,您可以通过脉冲轮廓测量(例如时间、电平、相位和频率)以及FM线性调频调制测量和幅度和相位的脉冲稳定性测量来分析脉冲信号。
    发布日期:2024/10/8
    包含的版本:2024 Q4完整版/运行版,版本号24.8.0
    64位完整版校验和:
    文件大小: 2067089408 字节 (1.93 GB)
    修改日期: 2024-10-17 11:23
    MD5: 6a0caa1ecc0215a0cea93f60da457d10
    SHA1: 8b9e43eb6b8a0bca4e294ceeef3ade90ac15dea4
    SHA256: b6b2fd4deca599abbc10019d4a40ecd8df58619f3abb851ee037bbfacb319417
    CRC32: fea58a44
    NI官方下载和百度网盘下载地址:
    RFmx Pulse2024Q4Full.txt (601 Bytes, 下载次数: 0, 售价: 10 元)
    64位运行版校验和:
    文件大小: 1016731648 字节 (969.63 MB)
    修改日期: 2024-10-17 11:21
    MD5: c277818ea9322d1aae251bebcd0ec22a
    SHA1: d5870cd20bce320e952d5c6ca6a305bb4064dccf
    SHA256: 495da07a56aed015989255bc51fae108dc3a4e43884bd33d9db0c96e7b733337
    CRC32: ba470952
    NI官方下载和百度网盘下载地址:
    RFmx Pulse2024Q4RTE.txt (632 Bytes, 下载次数: 0, 售价: 5 元)
    2024Q4版未更新自述文件,参考2023Q3版
    RFmx Pulse 2023 Q3 Readme
    This file contains important information about the RFmx Pulse, including system requirements, and installation instructions.
    • RFmx Pulse Release Notes: Known issues, and other notes about this release
    • RFmx Pulse Manuals: Features overview and other documentation
    Overview of Features
    Installed Software
    RFmx Pulse 2023 Q3 includes the following features:
    • Support for Pulse profile measurement results
      • Time
        • Rise Time, Fall Time, Pulse Width and PRI
      • Level
        • Top level, Base level, ON level, Droop, Overshoot, Ripple
      • Phase and Frequency
        • Average, Deviation and Error
    • Support for FM Chirp modulation results
    • Support for Pulse Stability measurements
      • Amplitude, Phase and Total
    • Support for Segmented and Single large record in Signal Acquisition methods
    RFmx Pulse has the following requirements:
    RFmx Pulse 2023 Q3 supports the following 64-bit operating systems:
    RFmx Pulse supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx Pulse. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx Pulse (64-bit only)
    Required Software
    If you are using the RFmx Pulse .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx Pulse .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the RFmx Pulse installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx Pulse. For more information on RFmx Pulse activation, refer to National Instruments Software Activation.
    Installed Software
      • Windows\system32 for 64-bit programs
    Item
    Installed Location
    Import Library files (64-bit)\Shared\ExternalCompilerSupport\C\lib64\msvc
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.PulseMX.Fx40.dll
    RFmx Pulse palette VIs are available from the Functions » Measurement I/O » RFmx » Pulse palette.
    Documentation for RFmx Pulse is located at Start » National Instruments » RFmx Pulse Documentation.
    You can access all the installed RFmx Pulse examples at Start » National Instruments » RFmx Pulse Examples.
    GMT+8, 2025-7-20 10:46
