查看: 470|回复: 0
[NI软件产品] NI RFmx NR 2024 Q4 Win11 64bitENG RFmx 5G新空口蜂窝测试24.8.0
    昨天 07:09
  • 签到天数: 3534 天
    连续签到: 4 天
     楼主| 发表于 2024-10-30 14:01:24 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx NR
    RFmx NR为5G新空口(NR)蜂窝测试应用提供信号生成和分析功能。
    RFmx NR是一款测量专用软件,旨在扩展NI RF仪器生成和分析5G新空口(NR)蜂窝信号的能力。该软件可以通过误差矢量幅度(EVM)、相邻信道泄漏比(ACLR)、频谱发射屏蔽(SEM)等符合标准的物理层测量,对FR1和FR2(毫米波)5G NR信号进行分析。借助RFmx,您可通过交互式软面板快速轻松地执行和调试测量,使用RFmx Waveform Creator创建和回放开放的未锁定波形,并结合更高性能的API加快自动化测试的速度。
    NI RFmx NR 2024 Q4
    发布日期:2024/10/8
    包含的版本:2024 Q4完整版/运行版,版本号24.8.0
    64位完整版校验和:
    文件大小: 2427320320 字节 (2.26 GB)
    修改日期: 2024-10-16 17:38
    MD5: 23d38d05923fe69c74b74c383d3745c1
    SHA1: 5550536b46b7b73d80caa152322d3fc0bb6739dc
    SHA256: 279013bdbb60a40d04b15753d29da9d14bd2695b49bf6e21e471b03413256079
    CRC32: 4914989a
    NI官方下载和百度网盘下载地址:
    RFmx NR2024Q4Full.txt (586 Bytes, 下载次数: 0, 售价: 10 元)
    64位运行版校验和:
    文件大小: 1054703616 字节 (1005.84 MB)
    修改日期: 2024-10-16 17:37
    MD5: 84444df806436f173f7d25962ac32c72
    SHA1: 13d590a617223580582ab54144c325b18244cc3a
    SHA256: cfac73a75ad548f22de6b98d7f6dc756a5896334229b35aead8e4ff4ac82ee0c
    CRC32: 0f983ae4
    NI官方下载和百度网盘下载地址:
    RFmx NR2024Q4RTE.txt (620 Bytes, 下载次数: 0, 售价: 5 元)
    2024Q4版未更新自述文件,参考2023Q3版本
    RFmx NR 2023 Q3 Readme
    This file contains important information about the RFmx NR, including system requirements, and installation instructions.
    • RFmx NR Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx NR Manuals: New features, behavior changes, and other documentation
    Installed Software
    RFmx NR 2023 Q3 includes the following new features:
    • Support for Noise Compensation in ACP measurement for Sequential FFT mode
    • Support for Reference Signal Transmit (RSTX) power measurement in ModAcc measurement
    • Support for NS_03U and NS_21 (Rel-17 onwards) masks in SEM measurement
    • Support for Band n54 in downlink SEM measurement
    RFmx NR 2023 Q2 includes the following new features:
    • Support for Phase Offset measurement
    • Support for Test Tolerance for NR-U band n46 in SEM measurement as per 3GPP Release 17 (December-2022)
    RFmx NR 2023 Q1 includes the following new features:
    • Support for EVM Measurement including symbols with Transient Period
    • Support for shared spectrum channels for n46, n96, and n102 bands in the SEM Measurement
    • Support for Power Class 6 in the IBE Measurement
    RFmx NR has the following requirements:
    RFmx NR 2023 Q3 supports the following 64-bit operating systems:
    RFmx NR supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx NR. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx NR (64-bit only)
    Required Software
    If you are using the RFmx NR .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx NR .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the RFmx NR installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx NR. For more information on RFmx NR activation, refer to National Instruments Software Activation.
    Installed Software
      • Windows\system32 for 64-bit programs
    Item
    Installed Location
    Import Library files (64-bit)\Shared\ExternalCompilerSupport\C\lib64\msvc
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.NRMX.Fx40.dll
    RFmx NR palette VIs are available from the Functions » Measurement I/O » RFmx » NR palette.
    Documentation for RFmx NR is located at Start » National Instruments » RFmx NR Documentation.
    You can access all the installed RFmx NR examples at Start » National Instruments » RFmx NR Examples.
    The following is the behavior change in RFmx NR 2023 Q3 from RFmx NR 2023 Q2
    The following are the behavior changes in RFmx NR 2022 Q3 from RFmx NR 21.8:
    • RFmx Soft Front Panel has been replaced by InstrumentStudio.
    The following are the behavior changes in RFmx NR 21.8 from RFmx NR 21.5:
    • RFmx NR drops support for 32-bit user mode.
    • Deprecated PDSCH present in SSB Resource Block.
    • Deprecated Subblock Freq Definition property. Use Subblock Freq (Hz) property for configuring subblock frequency offset from the center frequency.
    The following are the behavior changes in RFmx NR 21.3 from RFmx NR 20.7/20.7.1:
    • Updated downlink subblock integration bandwidth for ACP, CHP, and SEM measurements as per 38.104 CR0262.
    • Increased acquisition length for ModAcc measurement in the case of DFT-s-OFDM with SCS 60 kHz, and above with trigger types other than digital and sync mode other than Frame.
    GMT+8, 2025-5-10 06:06
