查看: 566|回复: 0
[NI软件产品] NI RFmx CDMA2000 2024 Q4 Full/Runtime Win11 64bitENG RFmxCDMA2K完整版运行版24.8.0下载
    前天 09:56
  • 签到天数: 3580 天
    连续签到: 13 天
     楼主| 发表于 2024-10-30 11:07:51 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx CDMA2000
    发布日期:2024/10/8
    包含的版本:2024 Q4完整版/运行版,版本号24.8.0
    64位完整版校验和:
    文件大小: 1135491072 字节 (1.06 GB)
    修改日期: 2024-10-16 18:09
    MD5: 06948a47afa039e8a26bf9b2d1b9cced
    SHA1: 624c65baf99c1f1136786fe8c03cc51a1a8ef2ba
    SHA256: 09ba460ab1257dfe0b2e85b1d366657f867b0c2f022892dd37fa4dcda800bee7
    CRC32: e146a4e2
    请注册登录视觉论坛,购买附件查看下载地址
    RFmx for Bluetooth Test2024Q4Full.txt (630 Bytes, 下载次数: 0, 售价: 10 元)
    64位运行版校验和:
    文件大小: 1021800448 字节 (974.46 MB)
    修改日期: 2024-10-16 18:11
    MD5: 591d1443819cbc1bfe94da131bda6558
    SHA1: 400cc6048ef285c1662d64cbe8524d90d04f996f
    SHA256: ec8bb2ef4b48b7afc30c683d4e7b955b44463c30f22ffc452d4dca34bedd7e8f
    CRC32: d072329c
    RFmx for Bluetooth Test2024Q4RTE.txt (658 Bytes, 下载次数: 0, 售价: 5 元)
    2024Q4版未更新自述文件,参考2023Q3版本
    RFmx CDMA2k 2023 Q3 Readme
    • RFmx CDMA2k Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx CDMA2k Manuals: New features, behavior changes, and other documentation
    Installed Software
    RFmx CDMA2k 2023 Q2 includes the following new feature:
    RFmx CDMA2k 2023 Q1 includes the following new feature:
    RFmx CDMA2k 2022 Q4 includes the following new features:
    • Support for PXIe-5842
    • Support for Downlink link direction in CDMA2k ModAcc measurement.
    RFmx CDMA2k 2023 Q3 supports the following 64-bit operating systems:
    Note    RFmx CDMA2k no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx CDMA2k 2023 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx CDMA2k 2023 Q3 to an unsupported OS. Additionally, after installing RFmx CDMA2k 2023 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx CDMA2k supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx CDMA2k. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx CDMA2k (64-bit only)
    Required Software
    Installed Software
    Item
    Installed Location
    Import Library files (64-bit)
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.CDMA2k.Fx40.dll
    Select Start » National Instruments» RFmx CDM2k Measurement Interactive Panel to launch the RFmx CDMA2k Measurement Interactive Panel.
    RFmx CDMA2k palette VIs are available from the Functions » Measurement I/O » RFmx » CDMA2K palette.
    Documentation for RFmx CDMA2k is located at Start » National Instruments » RFmx CDMA2k Documentation.
    You can access all the installed RFmx CDMA2k examples at Start » National Instruments » RFmx CDMA2k Examples.
    The following is the behavior change in RFmx CDMA2k 2023 Q3 from RFmx CDMA2k 2023 Q2
    The following is the behavior change in RFmx CDMA2k 2022 Q4 from RFmx CDMA2k 2022 Q3
    • RFmx CDMA2k drops support for 32-bit user mode.
    The following is the behavior change in RFmx CDMA2k 20.7 from RFmx CDMA2k 20.6.
    举报
    GMT+8, 2025-6-30 10:12
