查看: 976|回复: 0
[NI软件产品] NI RFmx for Bluetooth Test 2024 Q4 Win11 64bitEng RFmx蓝牙测试NIRFmxBluetooth24.8.0
     楼主| 发表于 2024-10-30 11:01:00 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx for Bluetooth Test为不同的蓝牙技术应用提供信号生成和分析功能。
    RFmx for Bluetooth Test是一款测量专用软件,旨在扩展NI RF仪器生成和分析常规蓝牙和低功率(LE)蓝牙信号的能力。该软件可以帮助您调制精度、载波频率漂移、发射功率(TXP)等符合标准的物理层测量,分析蓝牙信号(最高可支持蓝牙5.2)基本速率(BR)、增强型数据速率(EDR)和低功耗(LE)信号。借助RFmx,您可通过交互式软件前面板快速轻松地执行和调试测量,使用RFmx Waveform Creator创建和回放开放的、未锁定的波形,并并通过性能优化的API加快自动测试。此外,您可以使用RFmx for Bluetooth Test,通过内置的直接测试模式(DTM)命令来控制被测设备(DUT)。Bluetooth 为Bluetooth SIG公司的注册商标。
    发布日期:2024/10/8
    包含的版本:2024 Q4完整版/运行版,版本号24.8.0
    语言:英文English
    64位完整版校验和:
    文件大小: 2125989888 字节 (1.98 GB)
    修改日期: 2024-10-17 11:01
    MD5: 79c22c16f59836b60f77f92741a9ef24
    SHA1: ad9577d039d6cc08c40c4158c38b8018e3d1007e
    SHA256: 3f544f48f15e0400e44ab1f4674f53e9a0fad7914cda6bebab9d711f5567fc70
    CRC32: 756cb0f6
    RFmx for Bluetooth Test2024Q4Full.txt (630 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 1066498048 字节 (1017.09 MB)
    修改日期: 2024-10-17 11:00
    MD5: 5d24cf7341286eb1b96b8dc1cfd170e7
    SHA1: 13e2d414d493f95996e8a08a5d2056bc3eb7dbb7
    SHA256: 7408e6be2a81f3adfbbd6b7d48a14747fb2cf0f1bb3503dc78eb70645c95289e
    CRC32: 4777b4e8
    RFmx for Bluetooth Test2024Q4RTE.txt (658 Bytes, 下载次数: 0, 售价: 5 圆)
    2024Q4版未更新自述文件,参考2023Q3版
    RFmx for Bluetooth® Test 2023 Q3 Readme
    This file contains important information about the RFmx for Bluetooth® Test, including system requirements, and installation instructions.
    • RFmx for Bluetooth® Test Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx for Bluetooth® Test Manuals: New features, behavior changes, and other documentation
    Installed Software
    RFmx for Bluetooth® Test 2023 Q2 includes the following new features:
    • Support for Basic Rate, Enhanced Data Rate, and Low Energy versions of Bluetooth physical layer conforming to the Bluetooth Core Specification v5.4, and the Bluetooth RF PHY test specifications RF.TS.p30e2 and RF-PHY.TS.p15.
    • Support for Low Energy Direction Finding physical layer conforming to Bluetooth Core Specification v5.4
    RFmx for Bluetooth® Test 2023 Q1 includes the following new feature:
    RFmx for Bluetooth® Test 2022 Q4 includes the following new feature:
    • Support for DF2 and CFO measurements for Bluetooth LE 500kbps (S=2) packets
    • Support for PXIe-5842
    RFmx for Bluetooth® Test has the following requirements:
    RFmx for Bluetooth® Test 2023 Q3 supports the following 64-bit operating systems:
    Note    RFmx for Bluetooth® Test no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx for Bluetooth® Test 2023 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx for Bluetooth® Test 2023 Q3 to an unsupported OS. Additionally, after installing RFmx for Bluetooth® Test 2023 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx for Bluetooth® Test supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx for Bluetooth® Test. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx for Bluetooth® Test (64-bit only)
    Required Software
    If you are using the RFmx for Bluetooth® Test .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx for Bluetooth® Test .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the RFmx for Bluetooth® Test installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx for Bluetooth® Test. For more information on RFmx for Bluetooth® Test activation, refer to National Instruments Software Activation.
    Installed Software
    Item
    Installed Location
    Import Library files
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.BTMX.Fx40.dll
    RFmx for Bluetooth® Test palette VIs are available from the Functions » Measurement I/O » RFmx » BT palette.
    Documentation for RFmx for Bluetooth® Test is located at Start » National Instruments » RFmx for Bluetooth® Test Documentation.
    You can access all the installed RFmx for Bluetooth® Test examples at Start » National Instruments » RFmx for Bluetooth® Test Examples.
    The following is the behavior change in RFmx Bluetooth® Test 2023 Q3 from RFmx Bluetooth® Test 2023 Q2
    The following is the behavior change in RFmx for Bluetooth® Test 2022 Q4 from RFmx for Bluetooth® Test 2022 Q3:
    • RFmx for Bluetooth® Test drops support for 32-bit user mode.
    The following is the behavior change in RFmx for Bluetooth® Test 2022 Q3 from RFmx for Bluetooth® Test 21.8.2:
    The following are the behavior changes in RFmx for Bluetooth® Test 21.3 from RFmx for Bluetooth® Test 20.7.
    • Obsoleted ConfigureFrequencyChannelNumber(string, int, int) method in .NET. Use ConfigureFrequencyChannelNumber(string, RFmxBTMXStandard, int) method instead.
    GMT+8, 2026-1-13 14:23
