查看: 524|回复: 0
[NI软件产品] NI RFmx TD-SCDMA 2024 Q3 Patch 1 Win11 64bitENG RFmx蜂窝测试TD-SCDMA24.5.1
    昨天 07:09
  • 签到天数: 3534 天
    连续签到: 4 天
     楼主| 发表于 2024-10-16 15:19:28 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx TD-SCDMA
    发布日期:2024/8/20
    包含的版本:2024 Q3 Patch1完整版/运行版,版本号24.5.1
    64位完整版校验和:
    文件大小: 2062796800 字节 (1.92 GB)
    修改日期: 2024-07-26 15:40
    MD5: 8f167601e667ed7e089dc842bc139aac
    SHA1: a025efbd505078683c43174416d512bbc7a56b48
    SHA256: f0a5ccbb10e72c1c4da68c29f2b2b48ad255cf19d3b29a217b80e3d164f77417
    CRC32: 094e529f
    请注册登录机器视觉论坛用户,购买附件查看下载地址
    RFmx TD-SCDMA2024Q3Patch1.txt (620 Bytes, 下载次数: 0, 售价: 10 元)
    64位运行版校验和:
    文件大小: 934617088 字节 (891.32 MB)
    修改日期: 2024-07-27 17:23
    MD5: 2628005f02e4665b3057625bd5c2ffd0
    SHA1: ba9e73550654ab896618e6a4a7b87ff0b0ea0f80
    SHA256: 99d2d66d5a2684f50ec3a4288e1b20b4848a17b39a242a19de7b46e68c8294a0
    CRC32: 99a1f45a
    请注册登录视觉机器论坛用户,购买附件查看下载地址
    RFmx TD-SCDMA2024Q3Patch1RTE.txt (648 Bytes, 下载次数: 0, 售价: 5 元)
    2024Q3未更新自述文件,参考2023Q3版本
    RFmx TD-SCDMA 2023 Q3 Readme
    This file contains important information about the RFmx TD-SCDMA, including system requirements, and installation instructions.
    • RFmx TD-SCDMA Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx TD-SCDMA Manuals: New features, behavior changes, and other documentation
    Installed Software
    RFmx TD-SCDMA 2023 Q2 includes the following new feature:
    RFmx TD-SCDMA 2023 Q1 includes the following new feature:
    RFmx TD-SCDMA 2022 Q4 includes the following new feature:
    • Support for PXIe-5842
    RFmx TD-SCDMA has the following requirements:
    RFmx TD-SCDMA 2023 Q3 supports the following 64-bit operating systems:
    Note    RFmx TD-SCDMA no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx TD-SCDMA 2023 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx TD-SCDMA 2023 Q3 to an unsupported OS. Additionally, after installing RFmx TD-SCDMA 2023 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx TD-SCDMA supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx TD-SCDMA. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx TD-SCDMA (64-bit only)
    Required Software
    If you are using the RFmx TD-SCDMA .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx TD-SCDMA .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the RFmx TD-SCDMA installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx TD-SCDMA. For more information on RFmx TD-SCDMA activation, refer to National Instruments Software Activation.
    Installed Software
    Item
    Installed Location
    Import Library files
    RFmx TD-SCDMA palette VIs are available from the Functions » Measurement I/O » RFmx » TDSCDMA palette.
    Documentation for RFmx TD-SCDMA is located at Start » National Instruments » RFmx TD-SCDMA Documentation.
    You can access all the installed RFmx TD-SCDMA examples at Start » National Instruments » RFmx TD-SCDMA Examples.
    The following is the behavior change in RFmx TD-SCDMA 2023 Q3 from RFmx TD-SCDMA 2023 Q2
    The following is the behavior change in RFmx TD-SCDMA 2022 Q4 from RFmx TD-SCDMA 2022 Q3
    • RFmx TD-SCDMA drops support for 32-bit user mode.
    The following is the behavior change in RFmx TD-SCDMA 2022 Q3 from RFmx TD-SCDMA 21.8.2:
    The following is the behavior change in RFmx TD-SCDMA 20.7 from RFmx TD-SCDMA 20.6:
    GMT+8, 2025-5-10 05:44
