查看: 420|回复: 0
[NI软件产品] NI RFmx CDMA2000 2023 Q3 Patch 2 Full/Runtime Win11 64bitEng RFmxCDMA2K完整版运行版23.5.2下载
    昨天 07:09
  • 签到天数: 3534 天
    连续签到: 4 天
     楼主| 发表于 2024-10-15 10:19:00 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx CDMA2000
    发布日期:2023/9/8
    包含的版本:2023 Q3 Patch 2完整版/运行版,版本号23.5.2
    64位完整版校验和:
    文件大小: 847087616 字节 (807.85 MB)
    修改日期: 2024-10-15 10:03
    MD5: 36b46ee4b48e46e28bda378fd92d91bf
    SHA1: ef203c223b86a8bf979885f7b8139df727d8d913
    SHA256: 017f640532565545ea65a1ac29fd3cbaf574e6568d2ad81c717678175650f6b1
    CRC32: f6b4a760
    请注册登录视觉论坛,购买附件查看下载地址
    RFmx CDMA2K2023Q3Patch2.txt (617 Bytes, 下载次数: 0, 售价: 10 元)
    64位运行版校验和:
    文件大小: 671193088 字节 (640.10 MB)
    MD5: 12f57cd74825b0941c1187e25a19a655
    SHA1: 1b8412cc49e78cc07b8a9cc77f36b5775ffd839d
    SHA256: 76fa402008ce9e473f75479a9712eb112ee0b773de30e56abaddfafebaf5234d
    CRC32: 80683de0
    RFmx CDMA2K2023Q3Patch2RTE.txt (645 Bytes, 下载次数: 0, 售价: 5 元)
    RFmx CDMA2k 2023 Q3 Readme
    • RFmx CDMA2k Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx CDMA2k Manuals: New features, behavior changes, and other documentation
    Installed Software
    RFmx CDMA2k 2023 Q2 includes the following new feature:
    RFmx CDMA2k 2023 Q1 includes the following new feature:
    RFmx CDMA2k 2022 Q4 includes the following new features:
    • Support for PXIe-5842
    • Support for Downlink link direction in CDMA2k ModAcc measurement.
    RFmx CDMA2k 2023 Q3 supports the following 64-bit operating systems:
    Note    RFmx CDMA2k no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx CDMA2k 2023 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx CDMA2k 2023 Q3 to an unsupported OS. Additionally, after installing RFmx CDMA2k 2023 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx CDMA2k supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx CDMA2k. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx CDMA2k (64-bit only)
    Required Software
    Installed Software
    Item
    Installed Location
    Import Library files (64-bit)
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.CDMA2k.Fx40.dll
    Select Start » National Instruments» RFmx CDM2k Measurement Interactive Panel to launch the RFmx CDMA2k Measurement Interactive Panel.
    RFmx CDMA2k palette VIs are available from the Functions » Measurement I/O » RFmx » CDMA2K palette.
    Documentation for RFmx CDMA2k is located at Start » National Instruments » RFmx CDMA2k Documentation.
    You can access all the installed RFmx CDMA2k examples at Start » National Instruments » RFmx CDMA2k Examples.
    The following is the behavior change in RFmx CDMA2k 2023 Q3 from RFmx CDMA2k 2023 Q2
    The following is the behavior change in RFmx CDMA2k 2022 Q4 from RFmx CDMA2k 2022 Q3
    • RFmx CDMA2k drops support for 32-bit user mode.
    The following is the behavior change in RFmx CDMA2k 20.7 from RFmx CDMA2k 20.6.
    GMT+8, 2025-5-10 06:15
