查看: 625|回复: 0
[NI软件套件] HIL and Real-Time Test Software Suite 2024 Q3 Win11 32bitEn 硬件在环和实时测试软件套件24.5.0-32位英文
    昨天 07:09
  • 签到天数: 3534 天
    连续签到: 4 天
     楼主| 发表于 2024-10-15 09:32:53 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    HIL and Real-Time Test Software Suite是用于验证嵌入式软件和运行模型物理测试的软件集合。
    HIL and Real-Time Test Software Suite将LabVIEW集成开发环境(IDE)与应用软件和模块相结合,用于创建实时测试应用程序。借助该套件,您可以开发仿真模型和控制算法,并将其部署到实时硬件中。您还可以添加自定义功能,确保测试系统具有足够的灵活性来满足几乎任何应用需求,此外,您还可以在NI可重配置I/O硬件上执行高速仿真和处理。
    套件包含:
    LabVIEW专业版开发系统
    LabVIEW高级信号处理工具包
    VeriStand完整版开发系统
    LabVIEW Real-Time模块
    LabVIEW FPGA模块
    LabVIEW控制设计与仿真模块
    LabVIEW状态图模块
    相关NI设备驱动程序
    发布日期:2024/7/16
    包含版本:2024 Q3专业版,版本号24.5.0
    应用程序位数:32位
    语言:英文English
    文件大小: 37930346496 字节 (35.33 GB)
    修改日期: 2024-07-28 12:01
    MD5: adef3393f914e7476e4c1ae8333226b4
    SHA1: 526c3f8601838dfb0978ccd39b47e6806a1ba624
    SHA256: d8d1a87ea23686a73d9a13f85c269a2ff721479d8e66f670cc119a2f64ff941d
    CRC32: e0410439
    请注册登陆机器视觉论坛账号,购买附件查看下载地址
    HIL and Real-Time Test Software Suite2024Q3x86En.txt (727 Bytes, 下载次数: 0, 售价: 40 元)
    2024Q3版未更新自述文件,参考2023Q1版。
    HIL and Real-Time Test Software Suite 2023 Q1 Readme
    January 2023
    This file contains installation instructions and compatibility information for HIL and Real-Time Test Software Suite 2023 Q1.
    • HIL and Real-Time Test Software Suite Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    Products Included in the HIL and Real-Time Test Software Suite
    HIL and Real-Time Test Software Suite 2023 Q1 supports the following operating systems:
    The following products are included in the HIL and Real-Time Test Software Suite installer. This may not be a complete list of products that are activatable by your bundle serial number. Refer to the readme of each product for information including system requirements, installation, activation, known issues, and bug fixes.
    Application Software
    Version
    Bitness
    VeriStand202364-bit
    Add-ons
    Version
    Bitness
    JKI VI Package Manager2023 Q132-bit and 64-bit
    VeriStand Model Framework202132-bit and 64-bit
    VeriStand Model Generation Support for LabVIEW 2023 Q12023 Q132-bit and 64-bit
    Drivers
    Version
    Bitness
    NI-Industrial Communications for EtherCAT2023 Q132-bit and 64-bit
    Note: Some drivers included with previous versions of HIL and Real-Time Test Software Suite are not included with this release. Visit ni.com/downloads for the latest driver versions.
    If you are using the HIL and Real-Time Test Software Suite .NET Class Library, .NET Framework 4.0 (minimum) is required. The HIL and Real-Time Test Software Suite 2023 Q1 .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the HIL and Real-Time Test Software Suite installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using Package Manager.
    • Use the serial number that is included with your software to activate HIL and Real-Time Test Software Suite 2023 Q1. For more information on HIL and Real-Time Test Software Suite 2023 Q1 activation, refer to Activating a Product.
    Complete the following steps to install products using the HIL and Real-Time Test Software Suite media.
    • Insert the HIL and Real-Time Test Software Suite installation media.
    Save the original installation media in order to modify or repair your installation or to distribute NI software with your custom-built installers.
    Installing LabVIEW Add-Ons
    Installing LabVIEW add-ons, such as modules and toolkits, from the HIL and Real-Time Test Software Suite media ensures compatibility. Some versions of LabVIEW add-ons that are not found on the HIL and Real-Time Test Software Suite media may not work with the version of LabVIEW included in this release. Installing an incompatible add-on might cause some features in the add-on or LabVIEW to behave incorrectly.
    HIL and Real-Time Test Software Suite no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    GMT+8, 2025-5-10 05:55
