查看: 414|回复: 0
[NI软件产品] NI RFmx W-CDMA/HSPA+ 2024 Q3 Patch 1 Win11 64bitENG RFmx W-CDMA/HSPA/HSPA+蜂窝测试24.5.1
    昨天 07:09
  • 签到天数: 3534 天
    连续签到: 4 天
     楼主| 发表于 2024-10-12 16:12:50 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx W-CDMA/HSPA+
    发布日期:2024/8/20
    包含的版本:2024 Q3Patch1完整版/运行版,版本号24.5.1
    64位完整版校验和:
    文件大小: 2064887808 字节 (1.92 GB)
    修改日期: 2024-10-12 14:20
    MD5: 47e454860ca4d18a0c9c08d5405fdc4d
    SHA1: e11adc9bdb9d811bc2d4a0fc888268b44868ff83
    SHA256: 75a8cbf08abf54aac4214ceb0c56186d268b0048aaee6176810189f98e9417c8
    CRC32: 64458af2
    请注册登录视觉论坛账号,购买附件查看下载地址
    RFmx WCDMA2024Q3Patch1.txt (616 Bytes, 下载次数: 0, 售价: 10 元)
    64位运行版校验和:
    文件大小: 934490112 字节 (891.20 MB)
    修改日期: 2024-10-12 14:19
    MD5: c51984246ba1e545b96876eafc08c6fe
    SHA1: 2aa8890eb20a580a3f780366f2a82b7c994224d3
    SHA256: 39fecacb26d38261e28aae238e84cc892f1f8e2f8cc4ed7efc052deecdbc3e37
    CRC32: 81eab0f9
    RFmx WCDMA2024Q3Patch1RTE.txt (646 Bytes, 下载次数: 0, 售价: 5 元)
    2024Q3版未更新自述文件,参考2023Q3版本。
    RFmx WCDMA 2023 Q3 Readme
    • RFmx WCDMA Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx WCDMA Manuals: New features, behavior changes, and other documentation
    Installed Software
    RFmx WCDMA 2023 Q2 includes the following new feature:
    RFmx WCDMA 2023 Q1 includes the following new feature:
    RFmx WCDMA 2022 Q4 includes the following new feature:
    • Support for PXIe-5842
    RFmx WCDMA 2023 Q3 supports the following 64-bit operating systems:
    Note    RFmx WCDMA no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx WCDMA 2023 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx WCDMA 2023 Q3 to an unsupported OS. Additionally, after installing RFmx WCDMA 2023 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx WCDMA supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx WCDMA. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx WCDMA (64-bit only)
    Required Software
    Download the RFmx WCDMA installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx WCDMA. For more information on RFmx WCDMA activation, refer to National Instruments Software Activation.
    Installed Software
    Item
    Installed Location
    Import Library files
    RFmx WCDMA palette VIs are available from the Functions » Measurement I/O » RFmx » WCDMA palette.
    Documentation for RFmx WCDMA is located at Start » National Instruments » RFmx WCDMA Documentation.
    You can access all the installed RFmx WCDMA examples at Start » National Instruments » RFmx WCDMA Examples.
    The following is the behavior change in RFmx WCDMA 2023 Q3 from RFmx WCDMA 2023 Q2
    The following is the behavior change in RFmx WCDMA 2022 Q4 from RFmx WCDMA 2022 Q3
    • RFmx WCDMA drops support for 32-bit user mode.
    The following is the behavior change in RFmx WCDMA 2022 Q3 from RFmx WCDMA 21.8.2
    The following is the behavior change in RFmx WCDMA 20.7 from RFmx WCDMA 20.6.
    GMT+8, 2025-5-10 05:58
