查看: 1026|回复: 0
[NI驱动程序] NI RF Signal Generators 2023 Q1 Patch 4 Win11 32/64bitEng NI RF信号发生器NI-RFSG23.0.4
     楼主| 发表于 2024-9-29 16:59:31 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-RFSG
    NI-RFSG 2023 Q1 Patch 4
    发布日期:2023/10/26
    包含的版本:2023 Q1 Patch 4完整版,版本号23.0.4
    文件大小: 4454379520 字节 (4.15 GB)
    修改日期: 2024-09-28 18:46
    MD5: ac743e9d639c913e3f91fc7564fab9ea
    SHA1: 9eb52ac7f810aa9477c63b834b0a13294a2ed647
    SHA256: 4dacc3a2a1d40ce07e8897c180ebc42788d16b48074c66841d79385bdf7d340a
    CRC32: b400d0ed
    RFSG2023Q1Patch4.txt (576 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-RFSG 2023 Q1 Patch Readme
    March 2023
    This file contains installation instructions and compatibility information for NI-RFSG 2023 Q1 Patch.
    NI-RFSG 2023 Q1 Patch includes the following new feature:
    • Support for LabVIEW 2023 Q1
    NI-RFSG 2022 Q3 includes the following new feature:
    • Support for LabVIEW 2022 Q3
    • 4 GB RAM*
    Note  NI-RFSG 2023 Q1 Patch is not compatible with NI-RFSA 2.6. Upgrade to NI-RFSA 2.7 or later before installing NI-RFSG 2023 Q1 Patch.
    • NI Linux® Real-Time
    Versions Supported by NI-RFSG
    LabVIEW2020 and later
    LabWindows/CVI2019 and later
    Accessing the APILabVIEW
    LabWindows/CVI
    .NET Framework
    C
    NI-RFSG SFP
    Document
    Format
    Description
    • Hardware device overviews
    Few other documentation for NI-RFSG is located at Program Files\IVI Foundation\IVI\Drivers\niRFSG\documentation. This documentation set is composed of the following documents.
    Document
    Format
    Description
    GMT+8, 2026-1-13 09:37
