查看: 486|回复: 0
[NI驱动程序] NI RF Signal Generators 2024 Q1 Patch 1 Win11 32/64bitEng NI RF信号发生器NI-RFSG24.0.1
    昨天 07:09
  • 签到天数: 3534 天
    连续签到: 4 天
     楼主| 发表于 2024-9-29 16:50:06 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-RFSG
    NI-RFSG 2024 Q1 Patch 1
    发布日期:2024/2/20
    包含的版本:2024 Q1 Patch1完整版,版本号24.0.1
    文件大小: 4782118912 字节 (4.45 GB)
    修改日期: 2024-09-28 17:28
    MD5: c7d3def93b75cefbdc071c9a39e79e00
    SHA1: 388fac2817a164cd02972bb887ea7d5f311e9077
    SHA256: f32cb01a76b3627a3a2399ca85f55746532371ed78e538a4c2e61783a9ad2868
    CRC32: 52580399
    RFSG2024Q1Patch1.txt (576 Bytes, 下载次数: 0, 售价: 10 元)
    2024Q1Patch1版未更新自述文件,参考2023Q3版
    NI-RFSG 2023 Q3 Readme
    • Support for LabVIEW 2023 Q1
    • 4 GB RAM*
    • NI Linux® Real-Time
    Versions Supported by NI-RFSG
    LabVIEW2020 and later
    LabWindows/CVI2019 and later
    Accessing the APILabVIEW
    LabWindows/CVI
    .NET Framework
    C
    NI-RFSG SFP
    Document
    Format
    Description
    • Hardware device overviews
    Document
    Format
    Description
    GMT+8, 2025-5-10 05:40
