查看: 627|回复: 0
[NI驱动程序] NI RF Signal Generators 2024 Q2 Patch 1 Win11 32/64bitEng NI RF信号发生器NI-RFSG24.3.1
    昨天 07:09
  • 签到天数: 3534 天
    连续签到: 4 天
     楼主| 发表于 2024-9-29 16:46:10 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-RFSG
    NI-RFSG 2024 Q2 Patch 1
    发布日期:2024/5/4
    包含的版本:2024 Q2 Patch1完整版,版本号24.3.1
    文件大小: 4969482240 字节 (4.63 GB)
    修改日期: 2024-09-28 17:03
    MD5: b2dd2a70cf34e79fa2d3e68e6430a854
    SHA1: d8c5f791167fa9fd3c9390eabf12fc5700937ed5
    SHA256: 5e368b1798befefaec861b41367a6f11353a3b170f7c1d51ba45685d0525f9d2
    CRC32: beb2b293
    RFSG2024Q2Patch1.txt (576 Bytes, 下载次数: 0, 售价: 10 元)
    2024Q2Patch1版未更新自述文件,参考2023Q3版
    NI-RFSG 2023 Q3 Readme
    • Support for LabVIEW 2023 Q1
    • 4 GB RAM*
    • NI Linux® Real-Time
    Versions Supported by NI-RFSG
    LabVIEW2020 and later
    LabWindows/CVI2019 and later
    Accessing the APILabVIEW
    LabWindows/CVI
    .NET Framework
    C
    NI-RFSG SFP
    Document
    Format
    Description
    • Hardware device overviews
    Document
    Format
    Description
    GMT+8, 2025-5-10 05:25
