查看: 809|回复: 0
[NI驱动程序] NI RF Signal Generators 2023 Q1 Patch 3 Win11 32/64bitEng NI RF信号发生器NI-RFSG23.0.3
    昨天 08:56
  • 签到天数: 3596 天
    连续签到: 4 天
     楼主| 发表于 2024-9-29 16:35:43 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-RFSG
    NI-RFSG 2023 Q1 Patch 3
    发布日期:2023/9/30
    包含的版本:2023 Q1 Patch 3完整版,版本号23.0.3
    文件大小: 4454379520 字节 (4.15 GB)
    修改日期: 2024-09-28 17:54
    MD5: 1642c33b81d6af744eb0c38f22df02a4
    SHA1: f270e493d9b941972049343bae686c2b5cada5c0
    SHA256: b0d8847954c32b805cd3cad1b38c6150bd44943292884b651ab6be85c78475da
    CRC32: 03a5c407
    RFSG2023Q1Patch3.txt (576 Bytes, 下载次数: 0, 售价: 10 元)
    NI-RFSG 2023 Q1 Patch Readme
    March 2023
    This file contains installation instructions and compatibility information for NI-RFSG 2023 Q1 Patch.
    NI-RFSG 2023 Q1 Patch includes the following new feature:
    • Support for LabVIEW 2023 Q1
    NI-RFSG 2022 Q3 includes the following new feature:
    • Support for LabVIEW 2022 Q3
    • 4 GB RAM*
    Note  NI-RFSG 2023 Q1 Patch is not compatible with NI-RFSA 2.6. Upgrade to NI-RFSA 2.7 or later before installing NI-RFSG 2023 Q1 Patch.
    • NI Linux® Real-Time
    Versions Supported by NI-RFSG
    LabVIEW2020 and later
    LabWindows/CVI2019 and later
    Accessing the APILabVIEW
    LabWindows/CVI
    .NET Framework
    C
    NI-RFSG SFP
    Document
    Format
    Description
    • Hardware device overviews
    Few other documentation for NI-RFSG is located at Program Files\IVI Foundation\IVI\Drivers\niRFSG\documentation. This documentation set is composed of the following documents.
    Document
    Format
    Description
    GMT+8, 2025-7-18 09:08
