查看: 464|回复: 0
[NI驱动程序] NI RF Signal Generators 2023 Q1 Patch 2 Win11 32/64bitEng NI RF信号发生器NI-RFSG23.0.2
    昨天 07:09
  • 签到天数: 3534 天
    连续签到: 4 天
     楼主| 发表于 2024-9-29 16:28:06 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-RFSG
    NI-RFSG 2023 Q1 Patch 2
    发布日期:2023/6/2
    包含的版本:2023 Q1 Patch 2完整版,版本号23.0.2
    文件大小: 4454367232 字节 (4.15 GB)
    修改日期: 2024-09-28 17:46
    MD5: 6d9f5dddc768b531abf007a98dd611c5
    SHA1: dfd27bc36c8d0293abfbe2fecf7585251eadea9f
    SHA256: d4c91458cb92ef3cf7291684e3bd57e0fba0969106c6952bc9e47a387ef5f498
    CRC32: f86d4a8f
    RFSG2023Q1Patch2.txt (576 Bytes, 下载次数: 0, 售价: 10 元)
    NI-RFSG 2023 Q1 Patch Readme
    March 2023
    This file contains installation instructions and compatibility information for NI-RFSG 2023 Q1 Patch.
    NI-RFSG 2023 Q1 Patch includes the following new feature:
    • Support for LabVIEW 2023 Q1
    NI-RFSG 2022 Q3 includes the following new feature:
    • Support for LabVIEW 2022 Q3
    • 4 GB RAM*
    Note  NI-RFSG 2023 Q1 Patch is not compatible with NI-RFSA 2.6. Upgrade to NI-RFSA 2.7 or later before installing NI-RFSG 2023 Q1 Patch.
    • NI Linux® Real-Time
    Versions Supported by NI-RFSG
    LabVIEW2020 and later
    LabWindows/CVI2019 and later
    Accessing the APILabVIEW
    LabWindows/CVI
    .NET Framework
    C
    NI-RFSG SFP
    Document
    Format
    Description
    • Hardware device overviews
    Few other documentation for NI-RFSG is located at Program Files\IVI Foundation\IVI\Drivers\niRFSG\documentation. This documentation set is composed of the following documents.
    Document
    Format
    Description
    GMT+8, 2025-5-10 05:10
