查看: 483|回复: 0
[NI驱动程序] NI RF Signal Generators 2022 Q4 Patch 1 Win11 32/64bitEng NI RF信号发生器NI-RFSG22.8.1
    昨天 08:12
  • 签到天数: 3548 天
    连续签到: 18 天
     楼主| 发表于 2024-9-29 16:23:22 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-RFSG
    发布日期:2023/12/13
    包含的版本:2022 Q4 Patch 1完整版,版本号22.8.1
    文件大小: 4623898624 字节 (4.31 GB)
    修改日期: 2024-09-28 18:20
    MD5: ebb13a3f143a4fc1fe5b7eab33faf810
    SHA1: fd649fc40695cbf4c3abfa193a1e4bbc275d827a
    SHA256: ab657858e6197900a2e956eaad273dd3e47b195b98dbf54b09f9af9745f2516d
    CRC32: 8ff38fd8
    请注册登录视觉论坛账号,购买附件查看下载地址
    RFSG2022Q3Patch1.txt (576 Bytes, 下载次数: 0, 售价: 10 元)
    暂未发布2022Q4Patch1版本自述说明,参考2022Q3版本:
    NI-RFSG 2022 Q3 Readme
    July 2022
    This file contains installation instructions and compatibility information for NI-RFSG.
    • NI-RFSG Manuals: New features, behavior changes, and other documentation
    This software installation provides support for customers using RF signal generator or vector signal transceiver hardware, as specified in the Supported Hardware section. To program your device, use the NI-RFSG instrument driver or NI-RFSG Soft Front Panel (SFP).
    The getting started guide for your device provides information about how to install, configure, test, and begin using your hardware.
    NI-RFSG 2022 Q3 includes the following new feature:
    • Support for LabVIEW 2022
    NI-RFSG 21.8 includes the following new feature:
    • Support for NI Linux® Real-Time
    NI-RFSG 21.5 includes the following new feature:
    • Support for RF list mode on PXIe-5840/5841 for LO Source, Upconverter Frequency Offset Mode, and Signal Bandwidth attributes
    • 4 GB RAM*
    Note  NI-RFSG 2022 Q3 is not compatible with NI-RFSA 2.6. Upgrade to NI-RFSA 2.7 or later before installing NI-RFSG 2022 Q3.
    • NI Linux® Real-Time
    Versions Supported by NI-RFSG
    LabVIEW2019, 2020, 2021, and 2022
    LabWindows/CVI2018 to current
    LabVIEW Real-Time Module2021 and 2022
    Accessing the APILabVIEW
    LabWindows/CVI
    .NET Framework
    C
    NI-RFSG SFP
    Document
    Format
    Description
    • Hardware device overviews
    Few other documentation for NI-RFSG is located at Program Files\IVI Foundation\IVI\Drivers\niRFSG\documentation. This documentation set is composed of the following documents.
    Document
    Format
    Description
    NI-RFSG no longer installs IVI Compliance Package (ICP). NI-RFSG supports IVI configuration and runtime, but no longer installs the following IVI components:
    • IVI-COM Adapters
    举报
    GMT+8, 2025-5-24 09:37
