查看: 567|回复: 0
[NI驱动程序] NI RF Signal Generators 2024 Q3 Patch 2 Win11 32/64bitEng NI RF信号发生器NI-RFSG24.5.2
    昨天 08:04
  • 签到天数: 3559 天
    连续签到: 4 天
     楼主| 发表于 2024-9-28 17:15:51 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-RFSG
    NI-RFSG 2024 Q3 Patch 2
    发布日期:2024/8/30
    包含的版本:2024 Q3 Patch 2完整版,版本号24.5.2
    文件大小: 5544288256 字节 (5.16 GB)
    修改日期: 2024-09-28 16:00
    MD5: 8a5439675063d0051217d1c7b1746cbb
    SHA1: 410b96138012f4283981fb27d2855e48f3ea4398
    SHA256: b2eb83dfd6bf75a385ac09fb724d243f3e5aa92f7aff63bed865738a4de08d2e
    CRC32: 108fc621
    RFSG2024Q3Patch2.txt (576 Bytes, 下载次数: 0, 售价: 10 元)
    2024Q3Patch2版未更新自述文件,参考2023Q3版
    NI-RFSG 2023 Q3 Readme
    • Support for LabVIEW 2023 Q1
    • 4 GB RAM*
    • NI Linux® Real-Time
    Versions Supported by NI-RFSG
    LabVIEW2020 and later
    LabWindows/CVI2019 and later
    Accessing the APILabVIEW
    LabWindows/CVI
    .NET Framework
    C
    NI-RFSG SFP
    Document
    Format
    Description
    • Hardware device overviews
    Document
    Format
    Description
    GMT+8, 2025-6-7 04:11
