查看: 506|回复: 0
[NI驱动程序] NI RF Signal Generators 2024 Q3 Win11 32/64bitEng NI RF信号发生器NI-RFSG24.5.0
    前天 08:12
  • 签到天数: 3548 天
    连续签到: 18 天
     楼主| 发表于 2024-9-28 15:32:46 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-RFSG
    NI-RFSG 2024 Q3
    发布日期:2024/7/16
    包含的版本:2024 Q3完整版,版本号24.5.0
    文件大小: 5544302592 字节 (5.16 GB)
    修改日期: 2024-07-26 20:49
    MD5: 70f2d7eb866307bc755e8ec184cd1ea0
    SHA1: fbca7f12edb8f3e7971c8683907a6350b50df8b6
    SHA256: 1906e9e4576d490c88b0b9bee27b4de7ac940a548627c111476bb019c8860e91
    CRC32: 5e50e9e0
    RFSG2024Q3.txt (568 Bytes, 下载次数: 0, 售价: 10 元)
    2024Q3版未更新自述文件,参考2023Q3版
    NI-RFSG 2023 Q3 Readme
    • Support for LabVIEW 2023 Q1
    • 4 GB RAM*
    • NI Linux® Real-Time
    Versions Supported by NI-RFSG
    LabVIEW2020 and later
    LabWindows/CVI2019 and later
    Accessing the APILabVIEW
    LabWindows/CVI
    .NET Framework
    C
    NI-RFSG SFP
    Document
    Format
    Description
    • Hardware device overviews
    Document
    Format
    Description
    GMT+8, 2025-5-25 04:55
