NI ECU Test System Software Suite 22.1.3 x64Win10 64bitEng NI电子控制单元ECU测试系统软件套件ECUTS22.1.3
ECU测试系统软件套件
ECU测试系统套件包含了一套与ECU测试系统(ECUTS)搭配使用的软件。
ECU测试系统套件是一个软件套件,提供与ECUTS一起使用以测试汽车电子控制单元(ECU)所需的应用软件。该软件套件包括TestStand、Switch Executive、Instrument Studio、LabVIEW基本版、ECU测试系统维护软件、TestStand仪器抽象框架和所有必要的硬件驱动。
发布日期:2023/10/16
包含的版本:22.1.3完整版
程序位数:64位
文件大小: 14391662592 字节 (13.40 GB)
修改日期: 2024-09-18 19:17
MD5: 8ac291b5ae20b8791f95f1644cd98326
SHA1: 22adc264ded3100dce80df83f06f3c7cc75642c4
SHA256: 077815b82bf5a8e7b9cbf378a6e8038b2c4b7a8dc5aa3c0e3a4d6e50a31679f1
CRC32: 4acaab0b
注册登录视觉论坛账号,购买附件查看下载地址
ECU Test System Software Suite22.1.3.txt
(677 Bytes, 下载次数: 0, 售价: 25 圆)
ECU Test System Software Suite 22.1 ReadmeNovember 2022 This file contains important information about the ECU Test System Software Suite 22.1, including installation instructions. The ECU Test System Software Suite is a collection of NI software for developing, executing, debugging, and deploying test programs on the ECU Test System (ECUTS). You can find more release information on ni.com. - ECU Test System Software Suite Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
Included Components Installation Instructions Microsoft Visual Studio Support Product Security and Critical Updates New Features and Behavior Changes Accessing the Documentation Legal Information Included ComponentsThe ECU Test System Software Suite includes the following major components: - ECU Test System Maintenance Software 22.1
- InstrumentStudio 2022 Q4
- IVI Compliance Package 22.5
- LabVIEW 2021 SP1 (64-bit)
- TestStand 2021 SP1 (64-bit)
- TestStand ECU Software Toolkit 22.1
- NI Switch Executive 2021
- NI System Link Client 2022 Q4
- NI-488.2 22.8
- NI-DAQmx 22.8
- NI-DCPower 22.8
- NI-DMM 22.5
- NI-FGEN 21.8
- NI PXI Platform Services 22.8
- NI-SCOPE 22.5
- NI-Serial 21.5
- NI-SLSC 22.8
- NI-SWITCH 22.8
- NI-VISA 22.5
- NI-XNET 22.5
- RMX-410x Power Supply Driver for IVI-C 1.4
- Keysight AGN6700 Driver 3.5.1
Installation InstructionsThe ECUTS is delivered with the ECU Test System Software Suite 22.1 installed. If you need to install the ECU Test System Software Suite yourself, download the installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager. Notes - Use the serial number that is included with your software to activate the ECU Test System Software Suite. For more information on activating the ECU Test System Software Suite, refer to NI Software Activation.
Microsoft Visual Studio SupportIf you are using NI .NET Class Libraries, .NET Framework 4.0 (minimum) is required. The NI .NET Class Libraries can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5. To use the .NET API, you must install the .NET class libraries or the .NET wrapper in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to National Instruments .NET Driver Support. Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about NI products. For information about critical updates from NI, refer to Available Critical and Security Updates for NI Software. New Features and Behavior ChangesRefer to the readme for each component of the ECU Test System Software Suite for more information about new features and behavior changes in the ECU Test System Software Suite 22.1. Accessing the DocumentationYou can access installed ECUTS documentation from the ECUTS Documents shortcut on the desktop, from the %Public%\Documents\National Instruments\ECU Test System\Documentation directory, or online at ni.com/docs. ECUTS Safety, Environmental, and Regulatory Information sheets are only accessible online at ni.com/docs. The documentation set is composed of the following documents: Installed Documentation | Description | | ECUTS-16000 Specifications | Lists the technical specifications for your system. | | ECUTS-16001 Specifications | | ECUTS-16000 User Manual | Contains primary help content for your system, including:- An overview of supported hardware and software
- Site preparation and bring up information
- Basic procedures
- Maintenance and repair information
| | ECUTS-16001 User Manual | | TestStand ECU Software Toolkit Help | Explains the functionality the TestStand ECU Software Toolkit adds to TestStand. | | Configuration-Specific Reference | Contains unique information related to the configuration for an ECUTS
tester. This information is also included in the initial quote for
an ECU Test System. |
Online Documentation | Description | ECUTS-16000 Safety, Environmental, and Regulatory
Information | Lists the safety requirements for your system. | ECUTS-16001 Safety, Environmental, and Regulatory
Information | FDT-16041 Safety, Environmental, and Regulatory
Information | Lists the safety requirements for the FDT-16041 field diagnostic
tester. |
For the most recent revisions of documentation and for newly released documentation, visit ni.com/docs. Note To view PDFs, you need to have a PDF viewer such as Adobe Acrobat Reader installed. You can install the viewer from www.adobe.com/reader. Legal InformationCopyright © 2020–2022 National Instruments Corporation. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. NI respects the intellectual property of others, and we ask our users to do the same. NI software is protected by copyright and other intellectual property laws. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction. End-User License Agreements and Third-Party Legal Notices You can find end-user license agreements (EULAs) and third-party legal notices in the following locations after installation: - Review \_Legal Information.txt for information on including legal information in installers built with NI products.
U.S. Government Restricted Rights If you are an agency, department, or other entity of the United States Government ("Government"), the use, duplication, reproduction, release, modification, disclosure or transfer of the technical data included in this manual is governed by the Restricted Rights provisions under Federal Acquisition Regulation 52.227-14 for civilian agencies and Defense Federal Acquisition Regulation Supplement Section 252.227-7014 and 252.227-7015 for military agencies. Trademarks Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on NI trademarks. Other product and company names mentioned herein are trademarks or trade names of their respective companies. Patents For patents covering the NI products/technology, refer to the NI Patent Notice at ni.com/patents. |
