查看: 1864|回复: 0
[NI驱动程序] NI-488.2 2024 Q3 Driver Win11 32/64bit中文/德语/日语/法语/英文/韩语 NI IEEE488.2仪器驱动24.5.0离线版下载
    5 小时前
  • 签到天数: 3808 天
     楼主| 发表于 2024-9-11 10:50:34 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-488.2为使用NI GPIB控制器和带有GPIB端口的NI嵌入式控制器的客户提供支持。
    NI-488.2仪器驱动程序包含了几个实用程序,用于应用程序开发和调试。NI-488.2包含了可自动处理所有总线管理的高级命令,因而用户就无需了解GPIB硬件产品或IEEE 488.2协议的编程细节。为了提供最大灵活性和功能,NI-488.2还包含了底层命令。
    20.0版自述文件有中文版的,官方说明中也说支持中文, 日语, 英文, 韩语等,但是翻看资源包的Documents目录下,只有英文和日文的,估计仍然是只有安装界面与自述文件有中文,内在的资源仍然是没有中文化的。
    NI-488.2 2024 Q3
    发布日期:2024/7/16
    包含的版本:2024Q3完整版,版本号24.5.0
    语言:中文/德语/日语/法语/英文/韩语
    文件大小: 1666043904 字节 (1.55 GB)
    修改日期: 2024-07-28 16:59
    MD5: 37942df57724b7b47ea6f5253ee6e1d2
    SHA1: 742a6a3486a39042e7ddb35707baf1a4ef5378e9
    SHA256: b6cc900ec51ba40d6d4a805a261577751e7198305ada1efb5993eae254f67f1a
    CRC32: b402b1bf
    请注册视觉论坛会员,购买附件查看下载地址
    488.2 2024Q3.txt (573 Bytes, 下载次数: 0, 售价: 10 圆)
    2024Q3版本未更新自述文件,参考2023Q3
    NI-488.2 2023 Q3 Readme
    This file contains installation instructions and compatibility information for NI-488.2 2023 Q3.
    • NI-488.2 Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-488.2 Documentation: New features, behavior changes, and other documentation
    Unsupported Operating Systems
    NI-488.2 supports the following operating systems:
    • NI Linux® Real-Time
    Note NI-488.2 no longer supports any 32-bit Windows operating system. Refer to Unsupported Operating Systems for more information about unsupported OSes.
    NI-488.2 2023 Q3 supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by NI-488.2
    NI-VISA21.5 and later
    LabVIEW2020 and later
    LabVIEW Real-Time Module2022 and later
    Measurement Studio2019
    Note:  NI I/O Trace 17.0 and later support NI-488.2 17.0. Previous versions of NI I/O Trace do not support NI-488.2 17.0 or later.
    If you are using the NI-488.2 .NET Class Library, .NET Framework 4.0 (minimum) is required. The NI-488.2 .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    To use the .NET API, you must install the .NET class libraries or the .NET wrapper in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to National Instruments .NET Support.
    Microsoft Visual Basic 6.0 Support
    NI-488.2 supports 32-bit Visual Basic 6.0 application development. For more information, refer to the Language-Specific Programming Instructions topic in the NI-488.2 Help.
    Unmanaged C/C++ Support
    NI-488.2 supports 32-bit and 64-bit GPIB applications using Microsoft Visual C++ 2005 and later. Microsoft Visual C/C++ 6.0 and Microsoft Visual Studio .NET 2003 only support 32-bit GPIB applications. For more information, refer to the Language-Specific Programming Instructions topic in the NI-488.2 Help.
    Installation InstructionsInstalling NI-488.2 for LabVIEW
    You can install all of your LabVIEW products—including NI-488.2—using the LabVIEW Platform media.
    Note
    • If Windows Update is enabled, the installation process might hang if Windows Update interferes with the installation of Microsoft Visual C++ 2015 Run-Time. Visit ni.com/info and enter the Info Code exjq43 for more information and steps to resolve this issue.
    Refer to the NI-488.2 documentation, accessible by selecting National Instruments»NI-488.2»GPIB Help from the Windows menu bar.
    NI-488.2 no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    NI Software drops support for Phar Lap ETS Real-Time Operating System in 2022. Versions of this product that ship after May 1, 2022, may not install or execute correctly on this operating system. For high-level information on the support roadmap for Phar Lap and its replacement, NI Linux Real-Time, visit ni.com/r/xf35k1. To find out what hardware is supported on PXI controllers running NI Linux Real-Time, visit ni.com/r/b7g5wi.
    NI-488.2 no longer supports macOS starting from 2022 Q4.
    © 1995–2023 National Instruments Corporation. All rights reserved.
    GMT+8, 2026-2-25 14:58
