NI Vehicle Communication Software Suite 2023 Q3 Win11 64bitEng 车辆通信软件套件VCSS23.5.0
车辆通信软件套件
车辆通信软件套件可帮助您使用支持的设备进行汽车网络应用以及ECU设计和验证。
车辆通信软件套件包括Vehicle Communication工具包、以及Vehicle Communication的附加软件Vehicle Communication Measurement and Calibration工具包和Vehicle Communication Diagnostic工具包。这些附加工具可与LabVIEW中支持NI-XNET的设备配合使用,以处理汽车网络的Restbus仿真,并为ECU设计和验证提供NI-XNET设备支持,包括但不限于:读取和写入内部通过通用测量和校准协议(XCP)和CAN校准协议(CCP)测试ECU变量和特性。您还可以使用Vehicle Communication Software Suite执行诊断服务、读取诊断故障代码以及使用诊断数据库文件(PDX)和MCD-3D服务器刷新ECU。
发布日期:2023/10/3
包含的版本:2023 Q3完整版,版本号23.5.0
语言:英文English
文件大小: 4726755328 字节 (4.40 GB)
修改日期: 2024-06-05 16:21
MD5: ec1c315a4f2f589c52269043daa903d2
SHA1: 140c66ef229a201de97d321f5015659b2600b9bf
SHA256: 0b6a10a993de848eb7e76048e6450040c9825eb0ec5dc74b5d32ebcec28887e9
CRC32: 997aea95
注册登录视觉论坛账号,购买附件查看下载地址
Vehicle Communication Software Suite2023Q3.txt
(614 Bytes, 下载次数: 0, 售价: 25 圆)
车辆通信套件2023Q3未更新自述文件,参考车辆通信工具包2023Q1版
Vehicle Communication Software Suite 2023 Q3 Changes
Learn about new features, behavior changes, and other updates in Vehicle Communication Software Suite 2023 Q3. Vehicle Communication Toolkit New Features
- Base and Full Versions:
- Adds support for J1939 protocol
- Adds support for CAN and LIN virtual devices
- Adds support for multiple VCOM custom devices, each with unique configurations, in the same VeriStand project containing multiple controllers. Each controller can be associated with one VCOM custom device.
- Adds support for LabVIEW API signal selection in the Read and Write VIs.
- Adds support for deploying configuration files to remote targets from the WebUI rather than manually copying files between machines.
- Adds performance improvements for importing large .arxml files and large numbers of signals.
- Full Version Only:
- Adds support for optional Diagnostic Toolkit
- Adds support for AUTOSAR Global Time Synchronization
- The VeriStand Custom Device is now called NI:VCOM rather than Provetech:RBS
- The VeriStand Custom Device API is now located on the NI-VCOM:Restbus simulation palette
- The Measurement and Calibration Toolkit is now configured automatically.
- The VCOM custom device now creates channels that are not scalable by default, but you can set them to be scalable if necessary.
Vehicle Communication Toolkit (Full) 2023 Q1 ReadmeMarch 2023 This file contains important information about getting started with the Vehicle Communication Toolkit (Full) 2023 Q1, including system requirements and installation instructions. You can find more release information on ni.com. - Vehicle Communication Toolkit (Full) Release Notes: Known issues and other notes about this release
- Vehicle Communication Toolkit (Full) Manuals
System Requirements Supported Operating Systems Application Software Support Installation Instructions Product Security and Critical Updates Accessing the Documentation Finding Examples Automating the Installation of NI Products Using NI Software with Microsoft Windows 10 System RequirementsThe Vehicle Communication Toolkit (Full) 2023 Q1 has the following requirements: - At least 3 GB of disk space
Refer to the LabVIEW Readme for additional system requirements and supported operating systems for supported LabVIEW versions. Supported Operating SystemsThe Vehicle Communication Toolkit (Full) 2023 Q1 supports the following operating systems: - Windows 10 (64-bit)
- NI Linux® Real-Time (2022 Q3 system image)
Due to OS and compatibility limitations, the Vehicle Communication Toolkit is not compatible with real-time systems running a Pharlap operating system. The following table lists compatibilities between communication buses and operating systems: Communication Bus | Windows | NI Linux Real-Time | | NI-VCOM—CAN/CAN-FD (.dbc and .arxml database support) | Compatible | Compatible | | NI-VCOM—LIN (.ldf and .arxml database support) | Compatible | Compatible | | NI-VCOM—FlexRay (.arxml database support) | Compatible | Compatible | | NI-VCOM—Automotive Ethernet (.arxml database support) | Compatible | Compatible | Application Software SupportThe Vehicle Communication Toolkit (Full) 2023 Q1 supports the following application software versions, including service packs. Application Software | Versions Supported by Vehicle Communication Toolkit (Full) 2023 Q1 | | LabVIEW (32- and 64-bit) | 2020, 2021, 2022, 2023 | | LabVIEW Real-Time Module | 2019 (32-bit only), 2020 (32-bit only), 2021 (64-bit only), 2023 (64-bit only) | | VeriStand | 2020 (32-bit only), 2021 (64-bit only), 2023 (64-bit only) | | Microsoft Visual C/C++ | 2008 and later | Installation InstructionsIf your system uses PROVEtech:RBS, you must uninstall it and install the Vehicle Communication Toolkit instead since PROVEtech:RBS is no longer supported. The NI-VCOM palette is similar to that of PROVEtech:RBS, with the exception of two sets of VIs that are specific to the type of Vehicle Communication Toolkit license you hold. Download the Vehicle Communication Toolkit (Full) installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using Package Manager. After installing your software, you will need to activate it. Activating your software verifies the licenses associated with your NI account, so you can start using your software. You have different options for activation, based on your software and how it was purchased. Please visit ni.com/activate for more information on activation methods. If Windows Update is enabled, the installation process might hang if Windows Update interferes with the installation of Microsoft Visual C++ 2015 Run-Time. Visit ni.com/r/exjq43 for more information and steps to resolve this issue. Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about NI products. For information about critical updates from NI, refer to Available Critical and Security Updates for NI Software. Accessing the DocumentationRefer to the Vehicle Communication Toolkit User Manual, available at ni.com/docs, for more information about the Vehicle Communication Toolkit (Full). For more information on using the Vehicle Communication Toolkit API, refer to Vehicle Communication Toolkit API Help from the LabVIEW Help menu, the %Program Files (x86)%\National Instruments\LabVIEW\help\Vehicle Communication Toolkit directory, or the %Program Files%\National Instruments\LabVIEW\help\Vehicle Communication Toolkit directory. Finding ExamplesSelect Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for Vehicle Communication Toolkit (Full) are located in the LabVIEW\examples\Vehicle Communication Toolkit directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create. C/C++ examples and a demo ECU application for Vehicle Communication Toolkit (Full) are located in the %Public%\Documents\National Instruments\NI-VCOM\Examples directory. Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. For more information about automating the installation of NI products, refer to Automating an Installer in the NI Package Manager manual. Using NI Software with Microsoft Windows 10For more information about NI support for Windows 10, refer to NI Product Compatibility for Microsoft Windows 10. |
