NI RFmx WLAN 2024 Q2 Win11 64bitENG RFmx无线局域网络24.3.0
RFmx WLAN无线局域网络
RFmx WLAN为WLAN 802.11a/b/g/j/p/n/ac/ax/be测试应用提供信号生成和分析功能。
RFmx WLAN(Wireless Local Area Networks)是一个测量API,旨在扩展NI RF仪器生成和分析WLAN 802.11信号的能力。该软件可以通过误差矢量幅度(EVM)、频谱发射屏蔽(SEM)、发射功率(TXP)等符合标准的物理层测量,对802.11a/b/g/j/p/n/ac/ax/be信号进行分析。此外,你可以使用RFmx WLAN生成和分析多达8x8的多输入和多输出(MIMO)单用户和多用户信号,并为每个用户提供灵活的配置、损伤和结果。您可通过交互式软面板快速轻松地执行和调试测量,使用附带的RFmx Waveform Creator创建和回放开放的未锁定波形,并结合更高性能的API加快自动化测试的速度。
发布日期:2024/4/10
包含的版本:2024 Q2完整版,版本号24.3.0
64位完整版校验和:
文件大小: 1510133760 字节 (1.41 GB)
修改日期: 2024-04-11 09:45
MD5: 215936950de6f577e06684c57c603b63
SHA1: 06a257b62a02c8adbaa9e4bae041d27329144e0b
SHA256: 13231e07db4b36e207af2c906be062e2d319b7b921439e570f4ca28453bd10b1
CRC32: 299bf7a6
RFmx WLAN2024Q2Full.txt
(537 Bytes, 下载次数: 0, 售价: 10 圆)
64位运行版校验和:
文件大小: 953722880 字节 (909.54 MB)
MD5: a839fdd6d3cd08b327742d3b13f15a5f
SHA1: 0838592ace69e1af650a29877f3b4b8a146e23c1
SHA256: 0e1fe05a80eca719e85ee82225e98da878a8c5b80de4881d7433d46ad4b04a10
CRC32: b08472bf
RFmx WLAN2024Q2RTE.txt
(561 Bytes, 下载次数: 0, 售价: 5 圆)
2024Q2未更新自述文件,参考2023Q3版
RFmx WLAN 2023 Q3 ReadmeJuly 2023 This file contains important information about the RFmx WLAN, including system requirements, and installation instructions. You can find more release information on ni.com. - RFmx WLAN Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
- RFmx WLAN Manuals: New features, behavior changes, and other documentation
New Features Supported Hardware System Requirements Supported Operating Systems Application Software Support Installation Instructions Installed Software File Locations Executable Accessing the API Accessing the Documentation Finding Examples Product Security and Critical Updates Behavior Changes Automating the Installation of NI Products Using NI Software with Microsoft Windows 11 New FeaturesRFmx WLAN 2023 Q3 includes the following new features: - Support for 802.11be Standard IEEE P802.11be/D3.2
- Support for auto detection of signal in Analysis-Only Mode
RFmx WLAN 2023 Q2 includes the following new features: - Support for Combined Signal Demodulation across all MIMO standards
- Support for 802.11be Standard IEEE P802.11be/D3.0
- Speed improvements for Composite and Spectral measurements
RFmx WLAN 2023 Q1 includes the following new features: - Support for LabVIEW 2023 Q1 (64-bit)
- Support for Fields Gated Power for 802.11be standard
- Support for 802.11be Standard IEEE P802.11be/D2.3
Supported HardwareVisit NI Hardware and Operating System Compatibility to view driver, desktop operating system, and real-time operating system support for individual hardware devices. To view information for your device: - Select your hardware model in the dropdown list on the page to view compatibility information for your device.
Note: Some compatibility information may only be available in the archive attached to the NI Hardware and Operating System Compatibility page. For historic driver and OS support information, refer to the readme for the relevant driver version. System RequirementsRFmx WLAN has the following requirements: - Processor—1 GHz 64-bit (x64) processor
- 4 GB RAM *
- Any supported OS, with all available critical updates and service packs
* Depending on the amount of data acquired and/or processed, a larger amount of memory may be required. Supported Operating SystemsRFmx WLAN 2023 Q3 supports the following 64-bit operating systems: - Windows 11
- Windows 10
- Windows Server 2022
- Windows Server 2019
- Windows Server 2016
Note RFmx WLAN no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx WLAN 2023 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx WLAN 2023 Q3 to an unsupported OS. Additionally, after installing RFmx WLAN 2023 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS. Application Software SupportRFmx WLAN supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx WLAN. If you are not using NI application software, refer to Microsoft Visual Studio Support. Application Software | Versions Supported by RFmx WLAN (64-bit only) | LabVIEW | 2020 SP1, 2021 SP1 f1 patch, 2022 Q3, 2023 Q1, 2023 Q3 | Required Software- NI-RFSA 14.1 or later
- NI-RFSA 17.1 or later (for initializing debug session when "using breakpoints in C/C++/.NET application" is selected)
Microsoft Visual Studio SupportIf you are using the RFmx WLAN .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx WLAN .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5. Installation InstructionsDownload the RFmx WLAN installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager. Notes Notes - If Windows Update is enabled, the installation process might hang if Windows Update interferes with the installation of Microsoft Visual C++ 2015 Run-Time. Visit ni.com/r/exjq43 for more information and steps to resolve this issue.
- Use the serial number that is included with your software to activate RFmx WLAN. For more information on RFmx WLAN activation, refer to National Instruments Software Activation.
Installed Software- is an alias for the following National Instruments file folder location:
- Program Files (x86)\National Instruments\MeasurementStudioVS2010
- is an alias for the following file folder location:
- Windows\system32 for 64-bit programs
File LocationsItem | Installed Location | Version Compatibility Checker | \RFmx\niRFmxCompatibility_Checker.exe | Debug Configuration Utility | \RFmx\niRFmxDebugConfigurationUtility.exe | DLLs | | Header files | \Shared\ExternalCompilerSupport\C\include | Import Library files (64-bit) | \Shared\ExternalCompilerSupport\C\lib64\msvc | .NET Class Libraries | Assemblies | \DotNET\Assemblies\Current\NationalInstruments.RFmx.WlanMX.Fx40.dll
\DotNET\Assemblies\Current\NationalInstruments.Common.dll | ExecutableSelect Start » National Instruments » InstrumentStudio to launch the InstrumentStudio. Accessing the APIRFmx WLAN palette VIs are available from the Functions » Measurement I/O » RFmx » WLAN palette. Accessing the DocumentationDocumentation for RFmx WLAN is located at Start » National Instruments » RFmx WLAN Documentation. Finding ExamplesYou can access all the installed RFmx WLAN examples at Start » National Instruments » RFmx WLAN Examples. For the most recent revisions of documentation and for newly released documentation, visit ni.com/manuals. Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about NI products. For information about critical updates from NI, refer to Available Critical and Security Updates for NI Software. Behavior ChangesThe following is the behavior change in RFmx WLAN 2023 Q3 from RFmx WLAN 2023 Q2 - Added support for saving and loading RFmx configurations into/from rfmxconfig files. Load from TDMS is supported but save into TDMS files is discontinued.
The following are the behavior changes in RFmx WLAN 2022 Q3 from RFmx WLAN 21.8.2: - The RFmx Soft Front Panel has been replaced by InstrumentStudio.
- EVM Noise compensation includes support to work for Linear, Wiener and Triangular Smoothing channel estimation interpolation types
The following are the behavior changes in RFmx WLAN 21.8 from RFmx WLAN 21.5. - RFmx WLAN drops support for 32-bit user mode.
- When you set the OFDMModAcc Noise Comp Enabled property to True:
- Noise compensation applied limit check is now skipped if OFDMModAcc EVM Ref Data Symbols Mode property is set to Reference Waveform
- EVM per Subcarrier and the EVM per Symbol traces now follow the noise compensation applied result
The following are the behavior changes in RFmx WLAN 20.7 from RFmx WLAN 20.6. - Obsoleted the RFmxInstr Configure Automatic SG SA Shared LO API and the RFmxInstr Automatic SG SA Shared LO property. Use RFmxInstr LO Source property with Automatic_SG_SA_Shared value instead.
- Obsoleted RFmxWLAN OFDMModAcc Results HE-LTF Size property and RFmxWLAN OFDMModAcc Fetch HE-LTF Size API. Use RFmxWLAN OFDMModAcc Results LTF Size property and RFmxWLAN OFDMModAcc Fetch LTF Size API instead.
- Obsoleted RFmxWLAN OFDM HE-LTF Size property. Use RFmxWLAN OFDM LTF Size property instead.
- Obsoleted RFmxWLAN OFDM Num HE-LTF Symbols property. Use RFmxWLAN OFDM Num LTF Symbols property instead.
- Obsoleted public int FetchPpduInformation(string selectorString, double timeout, out RFmxWlanMXDsssModAccDataModulationFormat dataModulationFormat, out int payloadLength, out RFmxWlanMXDsssModAccPreambleType preambleType, out int lockedClocksBit, out int headerCrcStatus, out int psduCrcStatus) method. Use public int FetchPpduInformation(string selectorString, double timeout, out RFmxWlanMXDsssModAccDataModulationFormat dataModulationFormat, out int payloadLength, out RFmxWlanMXDsssModAccPreambleType preambleType, out int lockedClocksBit, out RFmxWlanMXDsssModAccPayloadHeaderCrcStatus headerCrcStatus, out RFmxWlanMXDsssModAccPsduCrcStaus psduCrcStatus) method instead.
Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. If the NI product you are installing uses Microsoft .NET 4.6.2, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.6.2 separately before you install NI software. For more information about automating the installation of NI products, refer to Automating an Installer in the NI Package Manager manual. Using NI Software with Microsoft Windows 11Microsoft Windows 11 is the latest version of the Windows operating system and features significant changes compared to previous versions. For more information about NI support for Windows 11, refer to NI Product Compatibility for Microsoft Windows 11. |
