NI RFmx W-CDMA/HSPA+ 2024 Q2 Win11 64bitENG RFmx W-CDMA/HSPA/HSPA+蜂窝测试24.3.0
RFmx W-CDMA/HSPA+
发布日期:2024/4/10
包含的版本:2024 Q2完整版/运行版,版本号24.3.0
64位完整版校验和:
文件大小: 1400363008 字节 (1.30 GB)
修改日期: 2024-04-11 09:45
MD5: e2f78c5808e5e17eed97a5af8ee22295
SHA1: 8a1cb7de1fe56ec0fe0fe7911daea5ff76f16f57
SHA256: 2bab92ca211862c978b2bca7946372769a400de511f185b02ab55f6bed50e421
CRC32: 03a33e77
请注册登录视觉论坛账号,购买附件查看下载地址
RFmx W-CDMA-HSPA 2024Q2Full.txt
(548 Bytes, 下载次数: 0, 售价: 10 圆)
64位运行版校验和:
文件大小: 929150976 字节 (886.11 MB)
修改日期: 2024-06-03 10:26
MD5: 40a4e196311860745d8a757505bfa6df
SHA1: a224b87c5d46083a5d9724ebd644dbe16a504841
SHA256: 3d78e0e92b47262c1bfbe4a8b8a7c738c6f9e0a102d02fa92548a328029f94c3
CRC32: 08b4fdd9
RFmx W-CDMA-HSPA 2024Q2RTE.txt
(572 Bytes, 下载次数: 0, 售价: 5 圆)
2024Q2版未更新自述文件,参考2023Q3版本。
RFmx WCDMA 2023 Q3 ReadmeJuly 2023 This file contains important information about the RFmx WCDMA, including system requirements, and installation instructions. You can find more release information on ni.com. - RFmx WCDMA Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
- RFmx WCDMA Manuals: New features, behavior changes, and other documentation
New Features Supported Hardware System Requirements Supported Operating Systems Application Software Support Installation Instructions Installed Software File Locations Executable Accessing the API Accessing the Documentation Finding Examples Product Security and Critical Updates Behavior Changes Automating the Installation of NI Products Using NI Software with Microsoft Windows 11 New FeaturesRFmx WCDMA 2023 Q2 includes the following new feature: - Speed improvements for Composite and Spectral measurements
RFmx WCDMA 2023 Q1 includes the following new feature: - Support for LabVIEW 2023 Q1 (64-bit)
RFmx WCDMA 2022 Q4 includes the following new feature: Supported HardwareVisit NI Hardware and Operating System Compatibility to view driver, desktop operating system, and real-time operating system support for individual hardware devices. To view information for your device: - Select your hardware model in the dropdown list on the page to view compatibility information for your device.
Note: Some compatibility information may only be available in the archive attached to the NI Hardware and Operating System Compatibility page. For historic driver and OS support information, refer to the readme for the relevant driver version. System RequirementsRFmx WCDMA has the following requirements: - Processor—1 GHz 64-bit (x64) processor
- 4 GB RAM *
- Any supported OS, with all available critical updates and service packs
* Depending on the amount of data acquired and/or processed, a larger amount of memory may be required. Supported Operating SystemsRFmx WCDMA 2023 Q3 supports the following 64-bit operating systems: - Windows 11
- Windows 10
- Windows Server 2022
- Windows Server 2019
- Windows Server 2016
Note RFmx WCDMA no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx WCDMA 2023 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx WCDMA 2023 Q3 to an unsupported OS. Additionally, after installing RFmx WCDMA 2023 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS. Application Software SupportRFmx WCDMA supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx WCDMA. If you are not using NI application software, refer to Microsoft Visual Studio Support. Application Software | Versions Supported by RFmx WCDMA (64-bit only) | LabVIEW | 2020 SP1, 2021 SP1 f1 patch, 2022 Q3, 2023 Q1, 2023 Q3 | Required Software- NI-RFSA 14.1 or later
- NI-RFSA 17.1 or later (for initializing debug session when "using breakpoints in C/C++/.NET application" is selected)
Microsoft Visual Studio SupportIf you are using the RFmx WCDMA .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx WCDMA .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5. Installation InstructionsDownload the RFmx WCDMA installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager. Notes - If Windows Update is enabled, the installation process might hang if Windows Update interferes with the installation of Microsoft Visual C++ 2015 Run-Time. Visit ni.com/r/exjq43 for more information and steps to resolve this issue.
- Use the serial number that is included with your software to activate RFmx WCDMA. For more information on RFmx WCDMA activation, refer to National Instruments Software Activation.
Installed Software- is an alias for the following National Instruments file folder location:
- Program Files (x86)\National Instruments\MeasurementStudioVS2010
- is an alias for the following file folder location:
- Windows\SysWOW64 for 32-bit programs and windows\system32 for 64-bit programs
File LocationsItem | Installed Location | Version Compatibility Checker | \RFmx\niRFmxCompatibility_Checker.exe | Debug Configuration Utility | \RFmx\niRFmxDebugConfigurationUtility.exe | DLLs | | Header files | \Shared\ExternalCompilerSupport\C\include | Import Library files | - 32-bit: \Shared\ExternalCompilerSupport\C\lib32\msvc
- 64-bit: \Shared\ExternalCompilerSupport\C\lib64\msvc
| .NET Class Libraries | Assemblies | \DotNET\Assemblies\Current\NationalInstruments.RFmx.WcdmaMX.Fx40.dll
\DotNET\Assemblies\Current\NationalInstruments.Common.dll | ExecutableSelect Start » National Instruments » InstrumentStudio to launch the InstrumentStudio. Accessing the APIRFmx WCDMA palette VIs are available from the Functions » Measurement I/O » RFmx » WCDMA palette. Accessing the DocumentationDocumentation for RFmx WCDMA is located at Start » National Instruments » RFmx WCDMA Documentation. Finding ExamplesYou can access all the installed RFmx WCDMA examples at Start » National Instruments » RFmx WCDMA Examples. For the most recent revisions of documentation and for newly released documentation, visit ni.com/manuals. Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about NI products. For information about critical updates from NI, refer to Available Critical and Security Updates for NI Software. Behavior ChangesThe following is the behavior change in RFmx WCDMA 2023 Q3 from RFmx WCDMA 2023 Q2 - Added support for saving and loading RFmx configurations into/from rfmxconfig files. Load from TDMS is supported but save into TDMS files is discontinued.
The following is the behavior change in RFmx WCDMA 2022 Q4 from RFmx WCDMA 2022 Q3 - RFmx WCDMA drops support for 32-bit user mode.
The following is the behavior change in RFmx WCDMA 2022 Q3 from RFmx WCDMA 21.8.2 - The RFmx Soft Front Panel has been replaced by InstrumentStudio.
The following is the behavior change in RFmx WCDMA 20.7 from RFmx WCDMA 20.6. - Obsoleted the RFmxInstr Configure Automatic SG SA Shared LO API and the RFmxInstr Automatic SG SA Shared LO property. Use RFmxInstr LO Source property with Automatic_SG_SA_Shared value instead.
Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. If the NI product you are installing uses Microsoft .NET 4.6.2, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.6.2 separately before you install NI software. For more information about automating the installation of NI products, refer to Automating an Installer in the NI Package Manager manual. Using NI Software with Microsoft Windows 11Microsoft Windows 11 is the latest version of the Windows operating system and features significant changes compared to previous versions. For more information about NI support for Windows 11, refer to NI Product Compatibility for Microsoft Windows 11. |
