查看: 458|回复: 0
[NI软件产品] NI RFmx TD-SCDMA 2024 Q2 Win11 64bitENG RFmx蜂窝测试TD-SCDMA24.3.0
    昨天 07:09
  • 签到天数: 3534 天
    连续签到: 4 天
     楼主| 发表于 2024-5-31 11:51:26 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx TD-SCDMA
    发布日期:2024/4/10
    包含的版本:2024 Q2完整版/运行版,版本号24.3.0
    64位完整版校验和:
    文件大小: 1397700608 字节 (1.30 GB)
    修改日期: 2024-04-11 09:44
    MD5: 13e3e39a2863f693d81d597dd80bda0a
    SHA1: 6d09a189ce578a72708f1ee81769276e92b63da0
    SHA256: fe6f40eb288a856f38c775774fca156a34040cd77436146fe33ddd65a76003a7
    CRC32: 8216d4bd
    请注册登录机器视觉论坛用户,购买附件查看下载地址
    RFmx TD-SCDMA2024Q2Full.txt (550 Bytes, 下载次数: 0, 售价: 10 元)
    64位运行版校验和:
    文件大小: 929288192 字节 (886.24 MB)
    MD5: ac2b322d53c8c087cf59e1981e080e38
    SHA1: 5ef03d31844a54b3e90ee871fb933ead3d5750d5
    SHA256: b1f7b67acd340f882e54aca483f5081f95895b2fc280ed9fb1cce002760d9791
    CRC32: c94b8116
    请注册登录视觉机器论坛用户,购买附件查看下载地址
    RFmx TD-SCDMA2024Q2RTE.txt (574 Bytes, 下载次数: 0, 售价: 5 元)
    2024Q2未更新自述文件,参考2023Q3版本
    RFmx TD-SCDMA 2023 Q3 Readme
    This file contains important information about the RFmx TD-SCDMA, including system requirements, and installation instructions.
    • RFmx TD-SCDMA Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx TD-SCDMA Manuals: New features, behavior changes, and other documentation
    Installed Software
    RFmx TD-SCDMA 2023 Q2 includes the following new feature:
    RFmx TD-SCDMA 2023 Q1 includes the following new feature:
    RFmx TD-SCDMA 2022 Q4 includes the following new feature:
    • Support for PXIe-5842
    RFmx TD-SCDMA has the following requirements:
    RFmx TD-SCDMA 2023 Q3 supports the following 64-bit operating systems:
    Note    RFmx TD-SCDMA no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx TD-SCDMA 2023 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx TD-SCDMA 2023 Q3 to an unsupported OS. Additionally, after installing RFmx TD-SCDMA 2023 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx TD-SCDMA supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx TD-SCDMA. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx TD-SCDMA (64-bit only)
    Required Software
    If you are using the RFmx TD-SCDMA .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx TD-SCDMA .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the RFmx TD-SCDMA installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx TD-SCDMA. For more information on RFmx TD-SCDMA activation, refer to National Instruments Software Activation.
    Installed Software
    Item
    Installed Location
    Import Library files
    RFmx TD-SCDMA palette VIs are available from the Functions » Measurement I/O » RFmx » TDSCDMA palette.
    Documentation for RFmx TD-SCDMA is located at Start » National Instruments » RFmx TD-SCDMA Documentation.
    You can access all the installed RFmx TD-SCDMA examples at Start » National Instruments » RFmx TD-SCDMA Examples.
    The following is the behavior change in RFmx TD-SCDMA 2023 Q3 from RFmx TD-SCDMA 2023 Q2
    The following is the behavior change in RFmx TD-SCDMA 2022 Q4 from RFmx TD-SCDMA 2022 Q3
    • RFmx TD-SCDMA drops support for 32-bit user mode.
    The following is the behavior change in RFmx TD-SCDMA 2022 Q3 from RFmx TD-SCDMA 21.8.2:
    The following is the behavior change in RFmx TD-SCDMA 20.7 from RFmx TD-SCDMA 20.6:
    GMT+8, 2025-5-10 09:14
