查看: 620|回复: 0
[NI软件产品] NI RFmx Pulse 2024 Q1 Win11 64bitENG RFmx脉冲分析仪24.0.0
    6 小时前
  • 签到天数: 3599 天
    连续签到: 7 天
     楼主| 发表于 2024-5-28 14:59:45 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx Pulse
    RFmx Pulse可帮助您执行交互式和自动化脉冲分析测量。
    RFmx Pulse是一款测量专用软件,可扩展NI RF仪器的脉冲分析功能,例如PXI矢量信号分析仪和PXI矢量信号收发器。借助RFmx Pulse,您可以通过脉冲轮廓测量(例如时间、电平、相位和频率)以及FM线性调频调制测量和幅度和相位的脉冲稳定性测量来分析脉冲信号。
    发布日期:2024/1/22
    包含的版本:2024 Q1完整版/运行版,版本号24.0.0
    64位完整版校验和:
    文件大小: 1355948032 字节 (1.26 GB)
    修改日期: 2024-01-23 10:01
    MD5: d42b38a8d0c2e67c0e3e0cbdfa539ca0
    SHA1: e2b2fe29a478991c272d072e9b2fda800cdc3fae
    SHA256: 16e7d733b7c48c7aee3055b2bd0ef4a968fcb3b2a44e95a5ab5feb11ad55d2ed
    CRC32: 533e6fd6
    NI官方下载和百度网盘下载地址:
    RFmx Pulse2024Q1Full.txt (541 Bytes, 下载次数: 0, 售价: 10 元)
    64位运行版校验和:
    文件大小: 922021888 字节 (879.31 MB)
    修改日期: 2024-01-23 10:02
    MD5: 629923289c05d096469ac9f221652dd7
    SHA1: 0a460721948771cef39b64cc336ce9ba2391c670
    SHA256: 074c4a1718c92c3b5656476c5f2fd202b7ca4254575b5d0af6e1a64aaaf14204
    CRC32: e86ae5a1
    NI官方下载和百度网盘下载地址:
    RFmx Pulse2024Q1RTE.txt (565 Bytes, 下载次数: 0, 售价: 5 元)
    2024Q1版未更新自述文件,参考2023Q3版
    RFmx Pulse 2023 Q3 Readme
    This file contains important information about the RFmx Pulse, including system requirements, and installation instructions.
    • RFmx Pulse Release Notes: Known issues, and other notes about this release
    • RFmx Pulse Manuals: Features overview and other documentation
    Overview of Features
    Installed Software
    RFmx Pulse 2023 Q3 includes the following features:
    • Support for Pulse profile measurement results
      • Time
        • Rise Time, Fall Time, Pulse Width and PRI
      • Level
        • Top level, Base level, ON level, Droop, Overshoot, Ripple
      • Phase and Frequency
        • Average, Deviation and Error
    • Support for FM Chirp modulation results
    • Support for Pulse Stability measurements
      • Amplitude, Phase and Total
    • Support for Segmented and Single large record in Signal Acquisition methods
    RFmx Pulse has the following requirements:
    RFmx Pulse 2023 Q3 supports the following 64-bit operating systems:
    RFmx Pulse supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx Pulse. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx Pulse (64-bit only)
    Required Software
    If you are using the RFmx Pulse .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx Pulse .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the RFmx Pulse installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx Pulse. For more information on RFmx Pulse activation, refer to National Instruments Software Activation.
    Installed Software
      • Windows\system32 for 64-bit programs
    Item
    Installed Location
    Import Library files (64-bit)\Shared\ExternalCompilerSupport\C\lib64\msvc
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.PulseMX.Fx40.dll
    RFmx Pulse palette VIs are available from the Functions » Measurement I/O » RFmx » Pulse palette.
    Documentation for RFmx Pulse is located at Start » National Instruments » RFmx Pulse Documentation.
    You can access all the installed RFmx Pulse examples at Start » National Instruments » RFmx Pulse Examples.
    GMT+8, 2025-7-20 16:28
