查看: 913|回复: 0
[NI软件产品] NI InstrumentStudio 2018 Win64Eng NI仪器套件2018 InstrumentStudio18.0.0
     楼主| 发表于 2024-5-24 09:34:59 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    InstrumentStudio
    InstrumentStudio是一款免费的应用程序软件,提供了集成的交互式PXI测量方法。
    InstrumentStudio可帮助您统一显示数据,将仪器配置导出到代码,并监测和调试您的自动测试系统。 您可以使用大型高分辨率显示器在统一显示界面上查看数据,然后捕获多仪器屏幕截图和测量结果。 您还可保存项目级配置,以便针对特定的待测设备更轻松地重复进行测试,或将仪器配置导出到编程环境,以简化代码并保证测量相关性。您还可以同时使用代码和InstrumentStudio来监测和调试正在运行的测试应用程序。
    发布日期:2018/5/15
    包含的版本:2018完整版,版本号18.0.0
    Windows 7 64-bit
    Windows 8.1 64-bit
    文件大小: 1825915868 字节 (1.70 GB)
    修改日期: 2023-01-21 09:56
    MD5: 281e1e8eaf0ad0f7e4966e237938026c
    SHA1: de2f88a9258de1c79df79173c72bd2c9b6a90bd7
    SHA256: 1272b0efda29fdfd53a38b30621aa234885a70d2889b6d4360a68608de14c5ca
    CRC32: e6f81f67
    请注册登录机器视觉论坛,购买附件后查看下载地址
    InstrumentStudio2018.txt (499 Bytes, 下载次数: 0, 售价: 10 圆)
    InstrumentStudio 2018 Readme
    May 2018
    This file contains important information about InstrumentStudio 2018, including supported hardware and operating systems, a partial list of bugs fixed, and known issues.
    InstrumentStudio 2018 allows you to generate and acquire measurements from multiple devices within a single application. You can also use InstrumentStudio 2018 to monitor and control devices being used in external applications, capture data files, export device configuration to other applications, and more.
    InstrumentStudio 2018 has the following requirements:
    • Pentium 4 G1 equivalent or later (Intel i5 equivalent or higher recommended)
    • 4 GB RAM
    • 4 GB disk space
    • 1024 x 768 screen resolution (1366 x 768 or higher recommended)
    InstrumentStudio 2018 supports the following operating systems:
    • Windows 10/8.11/7 SP12 (64-bit only)
    InstrumentStudio 2018 supports the creation of soft front panels with the following device drivers:
    Device Driver
    Versions Supported by InstrumentStudio 2018
    NI-SCOPE18.1
    NI-FGEN18.1
    NI-DMM18.1
    NI-DCPOWER18.1
    Installing InstrumentStudio 2018 with NI Package Manager
    NI automates installation of NI software using NI Package Manager. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    The following hardware models are supported in InstrumentStudio 2018:
    NI-DCPOWER Devices
    • PXIe-4112
    • PXIe-4113
    • PXIe-4135
    • PXIe-4136
    • PXIe-4137
    • PXIe-4138
    • PXIe-4139
    • PXIe-4140
    • PXIe-4141
    • PXIe-4142
    • PXIe-4143
    • PXIe-4144
    • PXIe-4145
    • PXIe-4154
    • PXIe-4162
    • PXIe-4163
    • PXI-4110
    • PXI-4130
    • PXI-4132
    NI-DMM Devices
    • PXIe-4080
    • PXIe-4081
    • PXIe-4082
    • PXI-4065
    • PXI-4070
    • PXI-4071
    • PXI-4072
    • PCI-4065
    • PCIe-4065
    • USB-4065
    • PCI-4070
    NI-FGEN Devices
    • PXIe-5413 (1-channel)
    • PXIe-5413 (2-channel)
    • PXIe-5423 (1-channel)
    • PXIe-5423 (2-channel)
    • PXIe-5433 (1-channel)
    • PXIe-5433 (2-channel)
    • PXIe-5442
    • PXIe-5450
    • PXIe-5451
    • PXI-5402
    • PXI-5404
    • PXI-5406
    • PXI-5412
    • PXI-5421
    • PXI-5422
    • PXI-5441
    • PCI-5402
    • PCI-5406
    • PCI-5412
    • PCI-5421
    NI-SCOPE Devices
    • PXIe-5105
    • PXIe-5114
    • PXIe-5122
    • PXIe-5160 (2-channel)
    • PXIe-5160 (4-channel)
    • PXIe-5162 (2-channel)
    • PXIe-5162 (4-channel)
    • PXIe-5164
    • PXIe-5170 (4-channel)
    • PXIe-5170 (8-channel)
    • PXIe-5171 (8-channel)
    • PXIe-5172 (4-channel)
    • PXIe-5172 (8-channel, 325T)
    • PXIe-5172 (8-channel, 410T)
    • PXIe-5185
    • PXIe-5185 (1MΩ)
    • PXIe-5186
    • PXIe-5186 (1MΩ)
    • PXIe-5622
    • PXIe-5622 (DD)
    • PXI-5105
    • PXI-5114
    • PXI-5122
    • PXI-5124
    • PXI-5142
    • PXI-5152
    • PXI-5153
    • PXI-5154
    • PXI-5922
    • PCI-5105
    • PCI-5114
    • PCI-5122
    • PCI-5124
    • PCI-5142
    • PCI-5152
    • PCI-5153
    • PCI-5154
    • PCI-5922
    • PCIe-5155
    • USB-5132
    • USB-5133
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in InstrumentStudio 2018. Visit ni.com/info and enter the Info Code InstrumentStudio2018KnownIssues for more information.
    © 2018 National Instruments. All rights reserved.
    377562A-01
    GMT+8, 2026-1-13 11:02
