查看: 604|回复: 0
[NI软件产品] NI DIAdem 2024 Q2 Win11 64bitJa NI数据管理软件DIAdem24.3.0日文版
    昨天 14:24
  • 签到天数: 3584 天
    连续签到: 4 天
     楼主| 发表于 2024-5-23 17:14:49 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    从2014版起,将默认包含DAC模块,不再另外发行DAC版本的DIAdem软件。从2015版起,提供32位、64位版本,且提供英德日三种语言版本。从2018版起,放弃32位版本,仅提供64位版本,同时有英德日三种语言版本。
    DIAdem 2024 Q2
    发布日期:2024/4/10
    包含的版本:2024 Q2 专业版、基本版、高级版,版本号24.3.0
    支持的操作系统:
    语言:Japanese
    文件大小: 1312045056 字节 (1.22 GB)
    修改日期: 2024-04-09 09:42
    MD5: 239507d00f63065237d1d50ac0ed4716
    SHA1: e7d1f0957e2623795725afc9c7fe5fe0d0824405
    SHA256: d828289295b49fb27a8897a7354cf45167e493a2b2a0bd7f225a15ea4919f243
    CRC32: b50e5e4a
    请注册登录视觉论坛用户,充值购买附件查看下载地址
    DIAdem2024Q2Ja.txt (550 Bytes, 下载次数: 0, 售价: 10 元)
    2024Q2版本未更新自述文件,参考2023Q2版本
    DIAdem 2023 Q2 Readme
    April 2023
    This file contains installation instructions and compatibility information for DIAdem 2023 Q2.
    • DIAdem Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • DIAdem Manuals: New features, behavior changes, and other documentation
    Behavior Changes and Notes
    DIAdem 2023 Q2 has the following requirements:
    CPUx64 compatible processor, 1.6 GHz or more
    Amount of memory2 GB or more
    Hard disk memoryDepending on the operating system, up to 6 GB free storage space on the system partition
    Graphic cardColor depth at least 16-bit (High Color), 24-bit, or 32-bit (True Color) recommended
    Screen resolutionFrom 1280x800 with a scaling step of 100%
    DIAdem 2023 Q2 supports the following operating systems:
    Download the DIAdem installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Help for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • If you purchased this product with an NI Product Bundle, use the installation media that shipped with your purchase to install this product.
    New FeaturesDIAdem NAVIGATOR, DataFinder, Data Portal
    • If a search for channel groups or channels has been performed, the context menu of the highlighted search result can be used to load the associated file containing the groups or channels found. It is also possible to select several search results and load their files.
    • When copying properties of the internal data using the AddProperties method, you can specify a channel or channel group as the source instead of a properties collection. This new option works faster and is especially recommended for many properties.
    DIAdem VIEW
    • Via the new display type Python graphic you can use a Python script to load or create a graphic depending on the cursor position and thereby extend your VIEW layout with any individual displays and diagram types. You can generate the graphic using a Python library, or you can perform an image export of a REPORT layout containing any REPORT objects.
    • As in REPORT, the OnLayoutLoaded event is now also available in VIEW, which is triggered after loading a layout. You can implement it using Python or VBS.
    DIAdem ANALYSIS
    • When resampling, NoValues can be included in the interpolation if desired. This is supported by the two commands ChnResampleFreqBased and ChnResampleChnBased.
    • The processing speed of the resampling functions has been significantly increased.
    • The ChnPeakFind command, for finding local minimum and maximum values, can now find up to 2 billion values.
    DIAdem REPORT
    • When exporting a PDF for a layout, Microsoft print to PDF is also offered. You can select Microsoft PDF export from the toolbar or call it in a script using the new command ExportToPDFMSPrint.
    • In the legend of a pie chart or ring diagram, you can use the two new variables CurrRelValue and CurrAbsValue to display the relative and absolute values of the pie sectors using a DIAdem expression.
    • If you want to edit an empty axis system, spider axis system or 2D table without creating channels or curves, this is possible by clicking the Skip button in the dialog for new entries. This will take you directly to the settings dialog of the REPORT object.
    • For a global color palette, the transparency for several colors can be set at the same time in the dialog for common settings. Thus, for markers in a 2D axis system, you no longer need to enter equal transparency values individually.
    DIAdem DAC
    • When acquiring GPS data, the global navigation satellite systems Galileo, GLONASS, Beidou and Quasi-Zenith Satellite System (QZSS) are now also supported.
    • Also when importing GPS data from file, the global navigation satellite systems Galileo, GLONASS, Beidou and Quasi-Zenith Satellite System (QZSS) are supported.
    DIAdem SCRIPT
    • Many Python code examples have been revised and improved in the help.
    • As of DIAdem 2023 Q2, DIAdem will no longer install Python. If you want to use Python scripts in DIAdem, install a Python version supported by DIAdem, which can be found at https://www.python.org/ . Make sure that the Python module PyWin32 is installed.
    • The names of Python user commands must be written in capital letters, such as ON_REPORT_LAYOUT_LOADED.
    • In Python, the parameters of a user function that receive a return value cannot be evaluated by DIAdem. Choose VBS syntax for these user commands.
    • If DIAdem 2023 Q2 is installed on a computer that already contains DIAdem 2022 Q2 or DIAdem 2022 Q4, the search area for the 2023 examples is no longer automatically created in My DataFinder. Add the directory C:\Program Files\National Instruments\DIAdem 2023\Examples manually to be able to search in the example data. Alternatively, you can index the files from My DataFinder, which will automatically create the search area for the examples.
    • For the MyDataFinder in DIAdem 2023 Q2, any index files from earlier DIAdem versions must be regenerated. This happens automatically when you start DIAdem if your previous DIAdem installation is DIAdem 2022 Q2 or older. Depending on how many files are to be indexed, this may take quite some time. If you had already installed DIAdem 2022 Q4, you have to start the indexing manually.
    • As of the DIAdem 2019 installation, the 64-bit version of My DataFinder replaces earlier 32-bit installations. The configuration of My DataFinder takes place in DIAdem versions 2019 or later in DIAdem. In DIAdem versions later than 2019, you configure My DataFinder using the tray icon in the Windows taskbar. C ++ DataPlugins, which are only available in a 32-bit version, need to upgrade to a 64-bit version.
    • As DIAdem 2018, you can no longer connect to My DataFinder from a remote computer.
    • Scripts written for the use on SystemLink analysis automation are subject to certain restrictions. Refer to Analysis Automation, General in the Help, for further information.
    • When you activate DIAdem, you must create a NI user profile at ni.com. The evaluation period is now 7 days without a user profile. If you create a user profile, this period is extended to 45 days.
    • When loading a DAC block diagram, DIAdem now checks whether the block diagram contains outdated blocks. The block diagram can still run with these blocks, however the outdated blocks are identified with a label. Please replace these by up-to-date blocks because in future versions the earlier blocks will no longer be supported.
    • In order to use the following DIAdem drivers the following NI software components must be installed:
      Driver
      Components
      Version
      ADCSAutomotive Diagnostic Command Set>= 18.0
      DAQmx driverNI-DAQmx>= 17.0
      ECU MCECU Measurement and Calibration Toolkit>= 18.0
      XNETNI-XNET>= 15.0
      Older hardware is no longer supported by the modified minimum requirements, including NI PCI-MIO-16XE-10 and NI PCI-MIO-16XE-50 in the PCMCIA version and NI 6533 as a DAQ card.
    • The 3D model display type in DIAdem-VIEW is no longer available as of DIAdem 2019.
    • Since DIAdem 2018, the ASAM-ODS6 standard is supported in order to have read access to the data store of an AOP6 server.
    • Very old commands and variables, which have been replaced by new technologies, are marked as obsolete in DIAdem. This means that these commands and variables are no longer supported in one of the upcoming DIAdem versions. On the DIAdem help page DIAdem»Searching for Obsolete Commands and Variables you can find a script which checks your scripts for obsolete identifiers.
    • The previously obsolete commands DataCheckChnls and DataSelChn have been permanently removed from DIAdem. Use the Selection collection instead.
    • If you install an earlier DIAdem version after you have installed the current DIAdem version, the PDF export of the earlier version might not function correctly. You can solve the issue by copying the files acfpdf*.* and cdintf*.dll from the current DIAdem program folder into the program folder of the earlier DIAdem version.
    • From version 2018 onwards, DIAdem imports VBS DataPlugins in encrypted form by default. You can only import and then process a DataPlugin unencrypted if you select Import DataPlugin in the DataPlugin Settings dialog box.
    • The images you use in the Picture for Tree SUD property must have a minimum size of 16*16 pixels.
    • You cannot use VIs that require .NET assemblies from DIAdem through the LVRuntime object.
    Preview Features
    Preview features give an outlook on features in future versions. The functions to be unlocked are still under development and the user interface, the API, or the scope of functions may change. Enable this function in the Settings»DIAdem Settings» Preview Features dialog box.
    • DIAdem supports complex channels. You can load and save complex channels. You can convert numeric channels to complex channels and vice versa.
    For more information on DIAdem, go to the DIAdem help Help»Contents.
    Use Help»Examples in DIAdem to start the DIAdem ExampleFinder. You can find DIAdem examples in the examples directory below the program directory. You can modify examples to suit your needs, or you can copy and paste parts of the examples into your own files.
    For more information about automating the installation of NI products, refer to Automating an Installer in the NI Package Manager Help.
    For more information about NI support for Windows 10, refer to Compatibility of NI Products with Microsoft Windows 10.
    DIAdem no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021 may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit http://www.ni.com/r/win32bitsupport.
    © 2003—2023 National Instruments Ireland Resources Limited. All rights reserved.
    Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. This includes photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation.
    NI respects the intellectual property of others, and we ask our users to do the same. NI software is protected by copyright and other intellectual property laws. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction.
    For more information on NI trademarks, refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks. Other product and company names mentioned herein are trademarks or trade names of their respective companies.
    For patents covering NI products/technology, refer to the patents.txt file on your media, or the National Instruments Patent Notice at ni.com/patents.
    举报
    GMT+8, 2025-7-5 06:40
