查看: 682|回复: 0
[NI软件产品] NI Vehicle Communication Diagnostic Toolkit 2023 Q3 Win11 64bitEng 车辆通信诊断工具包VCDT23.5.0
    昨天 11:15
  • 签到天数: 3597 天
     楼主| 发表于 2024-4-12 14:41:10 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    Vehicle Communication Diagnostic工具包可与支持NI-XNET的设备配合使用,为电子控制单元(ECU)设计和验证提供诊断应用程序。
    Vehicle Communication Diagnostic工具包是车辆通信工具包的软件附加Vehicle Communication工具包。该工具包可与诊断数据库文件(PDX)和MCD-3D服务器(未包含在诊断工具包中)配合使用,以执行诊断服务、读取诊断故障代码和刷新ECU。该工具包提供了一个用于Windows操作系统的LabVIEW和C/C++的API以及一个Web诊断数据库查看器。
    发布日期:2023/10/3
    包含的版本:2023 Q3基本版,完整版,版本号23.5.0
    语言:英文English
    文件大小: 1080276992 字节 (1.01 GB)
    修改日期: 2023-09-28 21:43
    MD5: 0863b12770f4f22860af9a03fdf926f2
    SHA1: 1ff9c516205183037aa89bab00da021834eb6b8d
    SHA256: 70af55409b1a8b8e72003871b6e79853b2d849938781a0fcb32b6f8bc73f5ba1
    CRC32: 950a421c
    注册登录视觉论坛账号,购买附件查看下载地址
    VCDT2023Q3.txt (578 Bytes, 下载次数: 0, 售价: 10 元)
    车辆通信诊断工具包没有自述文件,参考车辆通信工具包的。
    2023Q3未更新自述文件,参考2023Q1版
    Vehicle Communication Software Suite 2023 Q3 Changes
    Learn about new features, behavior changes, and other updates in Vehicle Communication Software Suite 2023 Q3.
    Vehicle Communication Toolkit New Features
    • Base and Full Versions:
      • Adds support for J1939 protocol
      • Adds support for CAN and LIN virtual devices
      • Adds support for multiple VCOM custom devices, each with unique configurations, in the same VeriStand project containing multiple controllers. Each controller can be associated with one VCOM custom device.
      • Adds support for LabVIEW API signal selection in the Read and Write VIs.
      • Adds support for deploying configuration files to remote targets from the WebUI rather than manually copying files between machines.
      • Adds performance improvements for importing large .arxml files and large numbers of signals.
    • Full Version Only:
      • Adds support for optional Diagnostic Toolkit
      • Adds support for AUTOSAR Global Time Synchronization
    • The VeriStand Custom Device is now called NI:VCOM rather than Provetech:RBS
    • The VeriStand Custom Device API is now located on the NI-VCOM:Restbus simulation palette
    • The Measurement and Calibration Toolkit is now configured automatically.
    • The VCOM custom device now creates channels that are not scalable by default, but you can set them to be scalable if necessary.
    Vehicle Communication Toolkit (Full) 2023 Q1 Readme
    March 2023
    This file contains important information about getting started with the Vehicle Communication Toolkit (Full) 2023 Q1, including system requirements and installation instructions.
    • Vehicle Communication Toolkit (Full) Release Notes: Known issues and other notes about this release
    • Vehicle Communication Toolkit (Full) Manuals
    The Vehicle Communication Toolkit (Full) 2023 Q1 has the following requirements:
    • At least 3 GB of disk space
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for supported LabVIEW versions.
    The Vehicle Communication Toolkit (Full) 2023 Q1 supports the following operating systems:
    • Windows 10 (64-bit)
    • NI Linux® Real-Time (2022 Q3 system image)
    Due to OS and compatibility limitations, the Vehicle Communication Toolkit is not compatible with real-time systems running a Pharlap operating system.
    The following table lists compatibilities between communication buses and operating systems:
    Communication Bus
    NI Linux Real-Time
    NI-VCOM—CAN/CAN-FD (.dbc and .arxml database support)CompatibleCompatible
    NI-VCOM—LIN (.ldf and .arxml database support)CompatibleCompatible
    NI-VCOM—FlexRay (.arxml database support)CompatibleCompatible
    NI-VCOM—Automotive Ethernet (.arxml database support)CompatibleCompatible
    The Vehicle Communication Toolkit (Full) 2023 Q1 supports the following application software versions, including service packs.
    Versions Supported by Vehicle Communication Toolkit (Full) 2023 Q1
    LabVIEW (32- and 64-bit)2020, 2021, 2022, 2023
    LabVIEW Real-Time Module2019 (32-bit only), 2020 (32-bit only), 2021 (64-bit only), 2023 (64-bit only)
    VeriStand2020 (32-bit only), 2021 (64-bit only), 2023 (64-bit only)
    Microsoft Visual C/C++2008 and later
    If your system uses PROVEtech:RBS, you must uninstall it and install the Vehicle Communication Toolkit instead since PROVEtech:RBS is no longer supported. The NI-VCOM palette is similar to that of PROVEtech:RBS, with the exception of two sets of VIs that are specific to the type of Vehicle Communication Toolkit license you hold.
    Download the Vehicle Communication Toolkit (Full) installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using Package Manager.
    Refer to the Vehicle Communication Toolkit User Manual, available at ni.com/docs, for more information about the Vehicle Communication Toolkit (Full).
    For more information on using the Vehicle Communication Toolkit API, refer to Vehicle Communication Toolkit API Help from the LabVIEW Help menu, the %Program Files (x86)%\National Instruments\LabVIEW\help\Vehicle Communication Toolkit directory, or the %Program Files%\National Instruments\LabVIEW\help\Vehicle Communication Toolkit directory.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for Vehicle Communication Toolkit (Full) are located in the LabVIEW\examples\Vehicle Communication Toolkit directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    C/C++ examples and a demo ECU application for Vehicle Communication Toolkit (Full) are located in the %Public%\Documents\National Instruments\NI-VCOM\Examples directory.
    GMT+8, 2025-7-19 17:43
