查看: 866|回复: 0
[NI软件产品] NI Vehicle Communication Toolkit 2023 Q1 Win11 64bitEng 车辆通信工具包VCT23.0.0
    昨天 16:26
  • 签到天数: 3674 天
     楼主| 发表于 2024-4-10 16:54:45 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    Vehicle Communication工具包
    Vehicle Communication工具包与NI-XNET支持的设备配合使用,可用于处理汽车网络的Restbus仿真。
    Vehicle Communication工具包是一款附加软件,可提供与Windows及NI Linux Real-Time操作系统兼容的LabVIEW API,以及与Windows兼容的C/C++ API。此外,该附加软件还包括一个VeriStand的定制设备。您可以将此附加软件与AUTOSAR XML等通信数据库文件一起使用,用于在支持NI-XNET的PXI、PCI、CompactDAQ及CompactRIO设备之间发送和接收控制器局域网(CAN)、本地互连网络(LIN)、Flexray或汽车以太网信号。借助Vehicle Communication工具包,您可以监测、发送或接受信号并测试待测设备(DUT)。
    Vehicle Communication工具包集成了AKKA技术的知识产权和产品,例如PROVEtech:RBS。
    注册商标Linux?的使用获得了Linus Torvalds专属授权商LMI的再授权,Linus Torvalds拥有Linux?注册商标在全球范围内的所有权。
    发布日期:2023/4/9
    包含的版本:2023 Q1基本版,完整版,版本号23.0.0
    语言:英文English
    文件大小: 2083708928 字节 (1.94 GB)
    修改日期: 2023-04-06 21:51
    MD5: 148620623c11c1e63e00a803f5d48ea2
    SHA1: de67cef3a7c89368695b6fe883a310e76cdb4b60
    SHA256: 3b0b97b0c7b23de05afcfcf9f12a9cdbb47b802c469eb5de9579632ec9f4cb22
    CRC32: 7e40362b
    注册登录视觉论坛账号,购买附件查看下载地址
    VCT2023Q1.txt (534 Bytes, 下载次数: 0, 售价: 10 圆)
    Vehicle Communication Toolkit (Full) 2023 Q1 Readme
    March 2023
    This file contains important information about getting started with the Vehicle Communication Toolkit (Full) 2023 Q1, including system requirements and installation instructions.
    • Vehicle Communication Toolkit (Full) Release Notes: Known issues and other notes about this release
    • Vehicle Communication Toolkit (Full) Manuals
    The Vehicle Communication Toolkit (Full) 2023 Q1 has the following requirements:
    • At least 3 GB of disk space
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for supported LabVIEW versions.
    The Vehicle Communication Toolkit (Full) 2023 Q1 supports the following operating systems:
    • Windows 10 (64-bit)
    • NI Linux® Real-Time (2022 Q3 system image)
    Due to OS and compatibility limitations, the Vehicle Communication Toolkit is not compatible with real-time systems running a Pharlap operating system.
    The following table lists compatibilities between communication buses and operating systems:
    Communication Bus
    NI Linux Real-Time
    NI-VCOM—CAN/CAN-FD (.dbc and .arxml database support)CompatibleCompatible
    NI-VCOM—LIN (.ldf and .arxml database support)CompatibleCompatible
    NI-VCOM—FlexRay (.arxml database support)CompatibleCompatible
    NI-VCOM—Automotive Ethernet (.arxml database support)CompatibleCompatible
    The Vehicle Communication Toolkit (Full) 2023 Q1 supports the following application software versions, including service packs.
    Versions Supported by Vehicle Communication Toolkit (Full) 2023 Q1
    LabVIEW (32- and 64-bit)2020, 2021, 2022, 2023
    LabVIEW Real-Time Module2019 (32-bit only), 2020 (32-bit only), 2021 (64-bit only), 2023 (64-bit only)
    VeriStand2020 (32-bit only), 2021 (64-bit only), 2023 (64-bit only)
    Microsoft Visual C/C++2008 and later
    If your system uses PROVEtech:RBS, you must uninstall it and install the Vehicle Communication Toolkit instead since PROVEtech:RBS is no longer supported. The NI-VCOM palette is similar to that of PROVEtech:RBS, with the exception of two sets of VIs that are specific to the type of Vehicle Communication Toolkit license you hold.
    Download the Vehicle Communication Toolkit (Full) installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using Package Manager.
    Refer to the Vehicle Communication Toolkit User Manual, available at ni.com/docs, for more information about the Vehicle Communication Toolkit (Full).
    For more information on using the Vehicle Communication Toolkit API, refer to Vehicle Communication Toolkit API Help from the LabVIEW Help menu, the %Program Files (x86)%\National Instruments\LabVIEW\help\Vehicle Communication Toolkit directory, or the %Program Files%\National Instruments\LabVIEW\help\Vehicle Communication Toolkit directory.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for Vehicle Communication Toolkit (Full) are located in the LabVIEW\examples\Vehicle Communication Toolkit directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    C/C++ examples and a demo ECU application for Vehicle Communication Toolkit (Full) are located in the %Public%\Documents\National Instruments\NI-VCOM\Examples directory.
    GMT+8, 2025-10-8 00:16
