查看: 915|回复: 0
[NI软件产品] NI Vehicle Communication Toolkit 1.0.0 x64Win10 32/64bitEng 车辆通信工具包VCT1.0.0
    昨天 16:26
  • 签到天数: 3674 天
     楼主| 发表于 2024-4-10 16:46:20 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    Vehicle Communication工具包
    Vehicle Communication工具包与NI-XNET支持的设备配合使用,可用于处理汽车网络的Restbus仿真。
    Vehicle Communication工具包是一款附加软件,可提供与Windows及NI Linux Real-Time操作系统兼容的LabVIEW API,以及与Windows兼容的C/C++ API。此外,该附加软件还包括一个VeriStand的定制设备。您可以将此附加软件与AUTOSAR XML等通信数据库文件一起使用,用于在支持NI-XNET的PXI、PCI、CompactDAQ及CompactRIO设备之间发送和接收控制器局域网(CAN)、本地互连网络(LIN)、Flexray或汽车以太网信号。借助Vehicle Communication工具包,您可以监测、发送或接受信号并测试待测设备(DUT)。
    Vehicle Communication工具包集成了AKKA技术的知识产权和产品,例如PROVEtech:RBS。
    注册商标Linux?的使用获得了Linus Torvalds专属授权商LMI的再授权,Linus Torvalds拥有Linux?注册商标在全球范围内的所有权。
    发布日期:2022/2/23
    包含的版本:1.0.0基本版,完整版,版本号1.0.0
    语言:英文English
    文件大小: 2323109888 字节 (2.16 GB)
    修改日期: 2022-03-25 19:30
    MD5: ae96cbed6ca3c02f158e35e233367c22
    SHA1: 5a13e4a50ab1f64d638dbe4b8ce815be1e3f167d
    SHA256: e76ea16385dc26e0e94242a583433c4f1b200f3dea1c0547289b0db8fb362637
    CRC32: e836c367
    注册登录视觉论坛账号,购买附件查看下载地址
    VCT1.0.0.txt (526 Bytes, 下载次数: 0, 售价: 10 圆)
    Vehicle Communication Toolkit (Full) 1.0 Readme
    January 2022
    This file contains important information about getting started with the Vehicle Communication Toolkit (Full) 1.0, including system requirements and installation instructions.
    • Vehicle Communication Toolkit (Full) Release Notes: Known issues and other notes about this release
    • Vehicle Communication Toolkit (Full) Manuals
    The Vehicle Communication Toolkit (Full), powered by AKKA, is a software add-on that allows you to monitor, send, and receive signals to a DUT. The Vehicle Communication Toolkit (Full) provides a LabVIEW API compatible with Windows and NI Linux Real-Time operating systems, a C/C++ API compatible with Windows, and a custom device for use with VeriStand. You can use the Vehicle Communication Toolkit (Full) with communication database files, such as AUTOSAR XML, to send and receive CAN, LIN, FlexRay, or automotive Ethernet signals to and from NI-XNET-supported PXI, PCI, CompactDAQ, and CompactRIO devices. The Vehicle Communication Toolkit incorporates intellectual properties and products such as PROVEtech:RBS from AKKA.
    The Vehicle Communication Toolkit offers a base and a full option. The following table lists a comparison of features included in the Vehicle Communication Toolkit (Full) and (Base) versions.
    Feature
    Vehicle Communication Toolkit (Base)
    C/C++ API (Windows only)
    LabVIEW API (Windows and NI Linux-RT)
    VeriStand Custom Device (Windows and NI Linux-RT)
    Web UI Database Viewer
    Web UI Configurator
    CAN and CAN-FD .DBC database Support
    LIN .LDF database support
    CAN and CAN-FD .ARXML database Support
    LIN .ARXML database Support
    Automotive Ethernet .ARXML database Support
    FlexRay .ARXML database Support
    The Vehicle Communication Toolkit (Full) 1.0 has the following requirements:
    • At least 3 GB of disk space
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for supported LabVIEW versions.
    The Vehicle Communication Toolkit (Full) 1.0 supports the following operating systems:
    • Windows 10 (64-bit)
    • NI Linux® Real-Time
    The Vehicle Communication Toolkit (Full) 1.0 supports the following application software versions, including service packs.
    Versions Supported by Vehicle Communication Toolkit (Full) 1.0
    LabVIEW2018, 2019, 2020, 2021
    VeriStand2018, 2019, 2020, 2021
    Microsoft Visual C/C++2008 and later
    Download the Vehicle Communication Toolkit (Full) installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using Package Manager.
    • You must have a valid license to activate the Vehicle Communication Toolkit (Full). Use the serial number that is included with your software to activate the Vehicle Communication Toolkit (Full). For more information on activation, refer to Activating a Product.
    Refer to the Vehicle Communication Toolkit User Manual, available at ni.com/manuals, for more information about the Vehicle Communication Toolkit (Full).
    Refer to Vehicle Communication Toolkit API Help, located in the C:\Program Files (x86)\National Instruments\LabVIEW 2020\help\Vehicle Communication Toolkit directory, for more information on using the Vehicle Communication Toolkit API.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for Vehicle Communication Toolkit (Full) are located in the labview\examples\NI-VCOM directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    C/C++ examples and a demo ECU application for Vehicle Communication Toolkit (Full) are locatd in the C:\Users\Public\Documents\National Instruments\NI-VCOM directory.
    © 2022 National Instruments Corporation. All rights reserved.
    The Demo ECU Application includes DQMH
    DQMH © 2022 DQMH Consortium, LLC. All rights reserved.
    378843A-01
    GMT+8, 2025-10-8 00:16
