查看: 998|回复: 0
[NI驱动程序] NI-VNA 2.0.1 Win32/64bitEng 矢量网络分析仪2.0.1下载
    16 分钟前
  • 签到天数: 3772 天
    连续签到: 23 天
     楼主| 发表于 2024-4-9 15:08:06 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-VNA
    NI-VNA为使用NI PXI矢量网络分析仪的客户提供支持。
    NI-VNA是控制所有NI PXI矢量网络分析仪所需的NI仪器驱动程序。您可以配置测量扫频、触发器和时域。您也可以自定义自动化测量并执行用户校准。该驱动软件包括基于IVI准则的灵活API、完整的硬件支持文档以及底层实用程序。NI-VNA包含了交互式软面板和示例。
    NI-VNA 2.0.1
    发布日期:2013/2/7
    包含的版本:2.0.1完整版,版本号2.0.1
    Windows 7 64-bit
    Windows Server 2008 R2 64-bit
    Windows XP 32-bit
    Windows Server 2003 R2 32-bit
    Windows 7 32-bit
    Windows Vista 64-bit
    Windows Vista 32-bit
    Windows 8 64-bit
    Windows 8 32-bit
    语言:英文English
    文件大小: 582315072 字节 (555.34 MB)
    修改日期: 2023-01-21 09:52
    MD5: adcb8858b9cf53dda8e8137d2c67162c
    SHA1: 5401785186adbde21213285e6186cffb3095b989
    SHA256: ff38fdb2242eb0e43b7d618186cd95da3cdbe3b5ff691fa622bb7b96f16dfb79
    CRC32: 8d5cb75a
    注册登录视觉论坛账号,购买附件查看下载地址
    VNA2.0.1.txt (472 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-VNA Readme
    Version 2.0.1
    Thank you for using NI-VNA. This file contains important information regarding NI-VNA and is organized into the following sections:
    • New Features
    • Supported Hardware
    • System Requirements
    • Documentation
    • Updates and Notifications
    • Uninstalling/Modifying NI-VNA
    • Known Issues
    • Bug Fixes
    • Licenses and Notices
    • How to Use NI Software with Microsoft Windows 8
    • Important Information
    NI-VNA 2.0.1 adds support for several bug fixes.
    NI-VNA 2.0 includes the following new features:
    • Support for the NI PXIe-5632
    • Adds support for LabVIEW 2012, and removes support for LabVIEW 8.6
    NI-VNA 1.2 includes the following new features:
    • Adds support for LabVIEW 2011, and removes support for LabVIEW 8.5
    • Performance improvement: CPU utilization
    NI-VNA 1.1 includes the following new features:
    • Support for the optional Time Domain feature
    • Support for specifying and loading a user-defined calibration kit
    • Includes firmware version 1.1, which is an optional update that improves the calibration file load time of the NI 5630. To upgrade your firmware, complete the following steps:
      • Navigate to the following directory: \IVI\Drivers\niVNA\utilities\FwUpdater.
      • Double-click NIVNAUtilities.exe.
      • Select the device to upgrade from the dialog box that appears. If only one device is available, selecting a device is unnecessary.
      • Click the Update Firmware button.
      • Select \IVI\Drivers\niVNA\utilities\FwUpdater\ni5630\Vesuvius_cfi_flash.bin as the firmware file.
      • Allow the firmware update process to complete before proceeding. Do not cycle the power during this update.
      • Restart the computer.
    The NI-VNA instrument driver supports the following devices on all Supported Operating Systems.
    • NI PXIe-5630
    • NI PXIe-5632
    Device-specific information about these modules is included in the NI Vector Network Analyzers Help.
    NI-VNA 2.0.1 and later supports the following operating systems:
    • Windows XP (32-bit)
    Note:  NI-VNA 2.0.1 and later does not support Windows Server non-R2 editions.
    It is recommended that you have the most recent service pack for your operating system installed.
    Minimum System Requirements
    • RAM—
      • Windows XP: 512 MB
      • Windows 8/7/Vista: 1 GB
    • 3 GB of hard drive space
    • Windows 8/7/Vista/XP, with all available critical updates and service packs
    Recommended System
    • RAM—
    If you are developing applications, your system must include one of the following installed application development environments (ADEs):
    • LabVIEW 2009 SP 1 (32-bit), 2009 SP 1 (64-bit), 2010 SP 1 (32-bit), 2010 SP 1 (64-bit), 2011 SP 1 (32-bit), 2011 SP 1 (64-bit), 2012 (32-bit), or 2012 (64-bit)
    • LabWindows™/CVI™ 9.0 or later
    Note:  You should install ADEs, such as NI LabVIEW, NI LabWindows/CVI or Microsoft Visual Studio®, before installing NI-VNA. To add support for ADEs installed after installing NI-VNA, modify your NI-VNA installation or launch the NI-VNA installer again.
      • Windows XP: Documents and Settings\All Users\Shared Documents\National Instruments
      • Windows 8/7/Vista: Users\Public\Documents\National Instruments
      • Windows 8 (32-bit)/7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI Foundation\IVI\
      • Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI Foundation\IVI\
        • Windows 8 (32-bit)/7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI\
        • Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI\
      • Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files\IVI Foundation\IVI\
        Note  $(IVIROOTDIR64) is configured as an environment variable on the target system.
    ItemInstalled Location on Windows 8 (32-bit)/7 (32-bit)/Vista (32-bit)/XP
    NI-VNA\Drivers\niVNA
    NI-VNA Function Panel\Drivers\niVNA\niVNA.fp
    NI-VNA Examples\niVNA\Examples
    NI-VNA Header files\Include
    NI-VNA Import Library files (32-bit)\Lib
    NI-VNA Import Library files (64-bit)\Lib_x64
    NI-VNA DLL (32-bit)\Bin
    Additional File Locations for Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit)
    ItemInstalled Location on Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit)
    NI-VNA DLL (64-bit)\Bin
    Documentation is available at Start»All Programs»National Instruments»NI-VNA»Documentation. The documentation set is composed of the following documents:
    • NI-VNA Readme (this document)
    • Getting Started Guide for your device—Printed and PDF format. Contains hardware and software installation, MAX configuration, and signal connection information.
    • NI Vector Network Analyzers Help—HTML Help format. Contains information about hardware and software for NI RF vector network analyzers. This help file contains an introduction to fundamental RF vector network analyzer concepts, guidelines for accurate measurements, and programming reference information for LabVIEW, C, and LabWindows™/CVI™.
    • Maintain Forced-Air Cooling Note to Users—Printed format. Contains important cooling information for NI vector network analyzers.
    • Read Me First: Safety and Electromagnetic Compatibility—Printed format. Contains safety instructions and electromagnetic compatibility (EMC) information for the hardware it accompanies.
    • Specifications document for your device—Printed format. Contains specifications for the capabilities and valid operating conditions of your NI device.
    Note  To view the specifications, you must have Adobe Acrobat Reader installed. You can install the viewer from www.adobe.com/acrobat.
    National Instruments releases critical software updates after product release using the NI Update Service. Visit ni.com/info and enter updates to view a list of all currently available updates.
    National Instruments provides notification of certain critical issues at install time. Visit ni.com/info and enter notifications to view a list of current product notifications.
    Perform the following procedure to uninstall NI-VNA 2.0.1:
    • Click Change/Remove.
    • Select NI-VNA 2.0.1 from the dialog box that appears.
    For Windows 8, complete the following steps:
    • Select Programs»Programs and Features.
    • Click the Uninstall button.
    As part of the NI-VNA installation, the following software is installed. To completely remove NI-VNA from your system, you must also remove all of the following packages:
    • NI IVI Compliance Package 4.4
    • NI Measurement & Automation Explorer (MAX) 5.0
    • NI-VISA Run-Time Engine 5.0
    You can access the software and documentation known issues list online. Refer to the NI-VNA Known Issues at ni.com for an up-to-date list of known issues in NI-VNA 2.0.1.
    The following items are changes in NI-VNA 2.0.1 from NI-VNA 2.0.
    378613Fixed an issue in which the NI PXIe-5632 periodically paused when sweeping with a low number of points and high IF bandwidth.
    375439Fixed an issue in which NI-VNA source power calibration incorrectly calibrated power when performing a segmented sweep.
    374013Fixed an issue in which NI-VNA incorrectly reported source-unleveled errors when performing a power sweep.
    374015Fixed an issue in which the NI-VNA Soft Front Panel freezed while performing a source power calibration during a power sweep.
    NI-VNA contains third-party software for which the following licenses and notices apply:
    • NI-VNA FOSS notices
    • Microsoft DotNet 2.0 License
    • Microsoft DirectX 9.0 License
    When you install National Instruments software on Microsoft Windows 8, you will notice a few additional tiles on the Start screen, including shortcuts to NI application software products such as NI LabVIEW and Measurement & Automation Explorer (MAX).
    Note  Unlike previous versions of Microsoft Windows, MAX does not appear as a desktop shortcut. You can launch MAX from the Start screen.
    Finding All Programs
    © 2010–2012 National Instruments. All rights reserved.
    GMT+8, 2026-1-14 08:56
