查看: 938|回复: 0
[NI软件产品] ASAM XIL TestStand Steps 1.5.0 Win11 32/64bitEng ASAM XIL TestStand步骤1.5.0下载
    15 分钟前
  • 签到天数: 3772 天
    连续签到: 23 天
     楼主| 发表于 2024-3-22 16:29:27 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    ASAM XIL TestStand Steps包括多个自定义步骤,支持使用TestStand重用HIL系统的序列。
    ASAM XIL TestStand Steps是一款附加软件,提供了一组自定义步骤。这些步骤可帮助您在TestStand中使用ASAM XIL API访问VeriStand软件并自动执行任务。借助这些自定义步骤,您可以复用硬件在环(HIL)系统的测试序列,并结合ASAM XIL API标准,在测试自动化工具和测试平台之间进行通信。ASAM XIL TestStand Steps支持实时序列、项目控制、通道读写访问、日志记录等功能。
    发布日期:2022/7/23
    包含的版本:1.5完整版,版本号1.5.0
    语言:英文English
    文件大小: 179431424 字节 (171.12 MB)
    修改日期: 2022-07-23 09:48
    MD5: 1565dc4dd6b2bb59a473f78736a796c1
    SHA1: 7950a7e1e90711ee8df599f251f1e6ac3a1e0dcf
    SHA256: 1f7684b44e297639adef56314cf0feeef56671387f8aedca63ec3d9371f06758
    CRC32: d2678640
    注册登录视觉论坛账号,购买附件查看下载地址
    ASAM XIL TestStand Steps1.5.txt (585 Bytes, 下载次数: 0, 售价: 10 圆)
    ASAM XIL Steps for TestStand 1.5 Readme
    July 2022
    This file contains installation instructions and compatibility information for ASAM XIL Steps for TestStand 1.5.
    • ASAM XIL Steps for TestStand Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    The ASAM XIL Steps for NI TestStand are sets of custom steps that allow you to reuse test sequences developed for other hardware-in-the-loop (HIL) systems that use the ASAM XIL API.
    Refer to the TestStand Readme for system requirements and supported operating systems for ASAM XIL Steps For TestStand 1.5.
    ASAM XIL Steps for TestStand 1.5 supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by ASAM XIL Steps for TestStand 1.5
    TestStand2017, 2019, 2020, 2021
    VeriStand2018, 2019, 2020, 2021
    If you are using the ASAM XIL Steps for TestStand .NET Class Library, .NET Framework 4.0 (minimum) is required. The ASAM XIL Steps for TestStand 1.5 .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the ASAM XIL Steps for TestStand installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using Package Manager.
    • Use the serial number that is included with your software to activate ASAM XIL Steps for TestStand. For more information on ASAM XIL Steps for TestStand activation, refer to Activating a Product.
    • Added support for TestStand 2021
    TestStand examples for the ASAM XIL Steps for TestStand are located in the \Examples\ASAM XIL directory. You can modify example sequences to fit an application, or you can copy and paste from one or more examples into a sequence that you create.
    ASAM XIL Steps for TestStand no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    © 2020–2022 National Instruments Corporation. All rights reserved.
    GMT+8, 2026-1-14 08:55
