查看: 931|回复: 0
[NI驱动程序] NI RF Signal Generators 2024 Q1 Win11 32/64bitEng NI RF信号发生器NI-RFSG24.0.0
    14 分钟前
  • 签到天数: 3772 天
    连续签到: 23 天
     楼主| 发表于 2024-3-12 14:55:59 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-RFSG
    NI-RFSG 2024 Q1
    发布日期:2024/1/22
    包含的版本:2024 Q1完整版,版本号24.0.0
    文件大小: 4710656000 字节 (4.39 GB)
    修改日期: 2024-01-23 09:43
    MD5: 9c1c1283ff4c77f12d60feecada2a7ee
    SHA1: 1f80d128b34a51b002d3695a638aa635bdcc076e
    SHA256: 401ad25266e775de26ad0852fc433194938013626fb3cfaff6e7cf78b071aa33
    CRC32: a799f995
    RFSG2024Q1.txt (514 Bytes, 下载次数: 0, 售价: 10 圆)
    2024Q1版未更新自述文件,参考2023Q3版
    NI-RFSG 2023 Q3 Readme
    • Support for LabVIEW 2023 Q1
    • 4 GB RAM*
    • NI Linux® Real-Time
    Versions Supported by NI-RFSG
    LabVIEW2020 and later
    LabWindows/CVI2019 and later
    Accessing the APILabVIEW
    LabWindows/CVI
    .NET Framework
    C
    NI-RFSG SFP
    Document
    Format
    Description
    • Hardware device overviews
    Document
    Format
    Description
    GMT+8, 2026-1-14 08:55
