NI RFmx GSM/EDGE+ 2024 Q1 Win11 64bitEng GSM/EDGE/EDGE Evolved蜂窝测试软件24.0.0
注册登陆后可查看附件和大图,以及购买相关内容您需要 登录 才可以下载或查看,没有账号?注册会员
 RFmx GSM/EDGE+
 RFmx GSM/EDGE+为GSM、EDGE和EDGE Evolved蜂窝测试应用提供了信号生成和分析功能。
 RFmx GSM/EDGE+是一款测量专用软件,旨在扩展NI RF仪器生成和分析GSM、EDGE和EDGE Evolved蜂窝信号的能力。该软件可以通过相位和频率误差、误差矢量幅度(EVM)、输出RF频谱(ORFS)、功率时间变化曲线(PVT) 等符合标准的物理层测量,对GSM、EDGE和EDGE Evolved信号进行分析。借助RFmx,您可通过交互式软面板快速轻松地执行和调试测量,使用RFmx Waveform Creator创建和回放开放的未锁定波形,并结合更高性能的API加快自动化测试的速度。
 发布日期:2024/1/22
 包含的版本:2024 Q1完整版/运行版,版本号24.0.0
 64位完整版校验和:
 文件大小: 1346476032 字节 (1.25 GB)
 修改日期: 2024-01-23 10:01
 MD5: f8361c4dc8ddace04a61e9e1520192b1
 SHA1: 7df373b6af5d588d331a10b2f0129ff24737b161
 SHA256: ad572d093add598d47330ba18dcfc2797c7823f55a2ccd9f2335ba8e985d2c08
 CRC32: 2465ea24
 NI官方下载和百度网盘下载地址:
 请注册登录视觉论坛账号,购买附件查看下载地址
  RFmx GSM2024Q1.txt
(539 Bytes, 下载次数: 0, 售价: 10 圆) 64位运行版校验和:
 文件大小: 911996928 字节 (869.75 MB)
 MD5: 96b2e321bc607f4c66557e4cc1eb03d4
 SHA1: faff0dc6a155490af464110e2c6faeb7a2367eca
 SHA256: 65dbc6074096c44d6565160bad971224508205444e34518e16cf242fe8e04294
 CRC32: a32ad177
 NI官方下载和百度网盘下载地址:
  RFmx GSM2024Q1RTE.txt
(563 Bytes, 下载次数: 0, 售价: 5 圆)
 2024Q1版未更新自述文件,参考2023Q3版本
 RFmx GSM 2023 Q3 Readme
 July 2023 This file contains important information about the RFmx GSM, including system requirements, and installation instructions. You can find more release information on ni.com. RFmx GSM Release Notes: Known issues, bugs fixed since the last release, and other notes about this releaseRFmx GSM Manuals: New features, behavior changes, and other documentation
 New Features Supported Hardware System Requirements Supported Operating Systems Application Software Support Installation Instructions Installed Software File Locations Executable Accessing the API Accessing the Documentation Finding Examples Product Security and Critical Updates Behavior Changes Automating the Installation of NI Products Using NI Software with Microsoft Windows 11 New Features
 RFmx GSM 2023 Q2 includes the following new feature: Speed improvements for Composite and Spectral measurements
 RFmx GSM 2023 Q1 includes the following new feature: Support for LabVIEW 2023 Q1 (64-bit)
 RFmx GSM 2022 Q4 includes the following new features: Supported HardwareSupport for PXIe-5842Support for configurable RBW in PVT measurement.
 Visit NI Hardware and Operating System Compatibility to view driver, desktop operating system, and real-time operating system support for individual hardware devices. To view information for your device: Select your hardware model in the dropdown list on the page to view compatibility information for your device.Type your hardware model number in the dropdown list on the web page to filter the list of available devices.
 Note: Some compatibility information may only be available in the archive attached to the NI Hardware and Operating System Compatibility page. For historic driver and OS support information, refer to the readme for the relevant driver version.System Requirements RFmx GSM has the following requirements: Processor—1 GHz 64-bit (x64) processor4 GB RAM *A screen resolution of 1,024 x 768Any supported OS, with all available critical updates and service packs
 * Depending on the amount of data acquired and/or processed, a larger amount of memory may be required.Supported Operating Systems RFmx GSM 2023 Q3 supports the following 64-bit operating systems: Windows 11Windows 10Windows Server 2022Windows Server 2019Windows Server 2016
 Note    RFmx GSM no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx GSM 2023 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx GSM 2023 Q3 to an unsupported OS. Additionally, after installing RFmx GSM 2023 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.Application Software Support RFmx GSM supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx GSM. If you are not using NI application software, refer to Microsoft Visual Studio Support. Required Software| Application Software | Versions Supported by RFmx GSM (64-bit only) |  | LabVIEW | 2020 SP1, 2021 SP1 f1 patch, 2022 Q3, 2023 Q1, 2023 Q3 |
 Microsoft Visual Studio SupportNI-RFSA 14.1 or laterNI-RFSA 17.1 or later (for initializing debug session when "using breakpoints in C/C++/.NET application" is selected)
 If you are using the RFmx GSM .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx GSM .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.Installation Instructions Download the RFmx GSM installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager. Notes Installed SoftwareIf Windows Update is enabled, the installation process might hang if Windows Update interferes with the installation of Microsoft Visual C++ 2015 Run-Time. Visit ni.com/r/exjq43 for more information and steps to resolve this issue.Use the serial number that is included with your software to activate RFmx GSM. For more information on RFmx GSM activation, refer to National Instruments Software Activation.
 File Locations is an alias for the following National Instruments file folder location:
 Program Files (x86)\National Instruments\MeasurementStudioVS2010
  is an alias for the following file folder location:
 Windows\SysWOW64 for 32-bit programs and windows\system32 for 64-bit programs
 Executable| Item | Installed Location |  | Version Compatibility Checker | \RFmx\niRFmxCompatibility_Checker.exe |  | Debug Configuration Utility | \RFmx\niRFmxDebugConfigurationUtility.exe |  | DLLs |  |  | Header files | \Shared\ExternalCompilerSupport\C\include |  | Import Library files | 32-bit: \Shared\ExternalCompilerSupport\C\lib32\msvc64-bit: \Shared\ExternalCompilerSupport\C\lib64\msvc
 |  | .NET Class Libraries |  | Assemblies | \DotNET\Assemblies\Current\NationalInstruments.RFmx.GsmMX.Fx40.dll \DotNET\Assemblies\Current\NationalInstruments.RFmx.InstrMX.Fx40.dll
 Select Start » National Instruments » InstrumentStudio to launch the InstrumentStudio.Accessing the API RFmx GSM palette VIs are available from the Functions » Measurement I/O » RFmx » GSM palette.Accessing the Documentation Documentation for RFmx GSM is located at Start » National Instruments » RFmx GSM Documentation.Finding Examples You can access all the installed RFmx GSM examples at Start » National Instruments » RFmx GSM Examples. For the most recent revisions of documentation and for newly released documentation, visit ni.com/manuals.Product Security and Critical Updates Visit ni.com/security to view and subscribe to receive security notifications about NI products. For information about critical updates from NI, refer to Available Critical and Security Updates for NI Software.Behavior Changes The following is the behavior change in RFmx GSM 2023 Q3 from RFmx GSM 2023 Q2 Added support for saving and loading RFmx configurations into/from rfmxconfig files. Load from TDMS is supported but save into TDMS files is discontinued.
 The following is the behavior change in RFmx GSM 2022 Q4 from RFmx GSM 2022 Q3 RFmx GSM drops support for 32-bit user mode.
 The following is the behavior change in RFmx GSM 2022 Q3 from RFmx GSM 21.8.2 The RFmx Soft Front Panel has been replaced by InstrumentStudio.
 The following items are behavior changes in RFmx GSM 20.7 from RFmx GSM 20.6. Automating the Installation of NI ProductsObsoleted RFmxInstr Configure Automatic SG SA Shared LO API and RFmxInstr Automatic SG SA Shared LO property. Use RFmxInstr LO Source property with Automatic_SG_SA_Shared value instead.
 You can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. If the NI product you are installing uses Microsoft .NET 4.6.2, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.6.2 separately before you install NI software. For more information about automating the installation of NI products, refer to Automating an Installer in the NI Package Manager manual.Using NI Software with Microsoft Windows 11 Microsoft Windows 11 is the latest version of the Windows operating system and features significant changes compared to previous versions. For more information about NI support for Windows 11, refer to NI Product Compatibility for Microsoft Windows 11. |
